StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F
Quicklinx: 8G46WS00 Mfr#: MXT10050CMBK
Length: 50cm
More than 50 in stock
£3.29 ex VAT
£3.94 inc VAT
Extend the connection between your DB9 serial devices by up to 0.5m. The MXT10050CMBK Black Serial Extension Cable (0.5m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - DB9 RS232 Serial Extension Cable - Male to Female Cable - 50cm (MXT10050CMBK) - serial extension cable - 50 cm
Serial extension cable
Shielded
Length
50 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: IC232TTL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232PRO, ICUSB232V2
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
50 cm
Connector
RoHS
8G46 StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £3.41
8G46 StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.01
8G46 StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.30
8G46 StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £3.29
Length: 50cm
Price Range Ex VAT: 0 - 50
