StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F
Quicklinx: 8G46WS00 Mfr#: MXT10050CMBK
£4.35 ex VAT
£5.22 inc VAT
Extend the connection between your DB9 serial devices by up to 0.5m. The MXT10050CMBK Black Serial Extension Cable (0.5m) features one DB9 male connector and one DB9 female connector, providing a high quality extension for your RS232 serial devices, which enables you to position your peripheral devices as needed.
  • Reliable data transmission
    The shielded design provides reliable data transmission, preventing interference and ensuring consistent signal quality.
  • Versatile connectivity
    The 9-pin D-Sub connectors enable versatile connectivity, allowing for use with numerous devices in different applications.
  • Durable construction
    Nickel plating on connectors enhances durability and resistance to corrosion, prolonging the cable's life.
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - DB9 RS232 Serial Extension Cable - Male to Female Cable - 50cm (MXT10050CMBK) - serial extension cable - DB-9 to DB-9 - 50 cm
Serial extension cable
Shielded
Length
50 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: 1P3FPC-USB-SERIAL, IC232TTL, ICUSB2321F, ICUSB2324, ICUSB2324I, ICUSB232D, ICUSB232PRO, ICUSB232V2
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
50 cm
Connector
RoHS
