StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 84NNWS00 Mfr#: N6PATC50CMBK
Length: 50cm
Colour: Black
Hurry, only 2 left in stock!
£3.63 ex VAT
£4.35 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC50CMBK Cat 6 Patch Cable (0.5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable black PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a cheaper cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • High-frequency performance
    The CAT6 Ethernet cable is tested to operate at frequencies up to 500 MHz, ensuring fast and efficient data transfer suitable for various applications.
  • Durable construction
    This cable features molded and snagless connectors, preventing damage during installation and providing a reliable connection over time.
  • Quality connectors
    Equipped with gold-plated RJ-45 connectors, this cable enhances conductivity and minimizes signal loss, which is crucial for maintaining high-speed connections.
  • Flexible and resilient
    The PVC jacket offers durability and flexibility, making installation effortless in various environments.
  • Standards compliant
    This Ethernet cable meets important industry standards such as RoHS, ETL, and TIA/EIA-568-B, ensuring safety and reliability.
StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Black, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMBK) - patch cable - 50 cm - black
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
50 cm
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
84NN StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.63
84NN StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.63
84NN StarTech.com 0.5m Gray Cat6 Patch Cable In Stock £3.62
84NN StarTech.com 0.5m Green Cat6 Patch Cable In Stock £3.63
84NN StarTech.com 0.5m Orange Cat6 Patch Cable In Stock £3.55
84NN StarTech.com 0.5m Purple Cat6 Patch Cable In Stock £3.76
84NN StarTech.com 0.5m Red Cat6 Patch Cable In Stock £3.63
84NN StarTech.com 0.5m White Cat6 Patch Cable In Stock £3.63
84NN StarTech.com 0.5m Yellow Cat6 Patch Cable In Stock £3.76
Length: 50cm
Colour: Black
