Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC50CMBK Cat 6 Patch Cable (0.5m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable black PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a cheaper cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
High-frequency performance
The CAT6 Ethernet cable is tested to operate at frequencies up to 500 MHz, ensuring fast and efficient data transfer suitable for various applications. -
Durable construction
This cable features molded and snagless connectors, preventing damage during installation and providing a reliable connection over time. -
Quality connectors
Equipped with gold-plated RJ-45 connectors, this cable enhances conductivity and minimizes signal loss, which is crucial for maintaining high-speed connections. -
Flexible and resilient
The PVC jacket offers durability and flexibility, making installation effortless in various environments. -
Standards compliant
This Ethernet cable meets important industry standards such as RoHS, ETL, and TIA/EIA-568-B, ensuring safety and reliability.
- StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Black, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMBK) - patch cable - 50 cm - black
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Molded, snagless
- Length
- 50 cm
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.54 |
StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.53 |
StarTech.com 0.5m Gray Cat6 Patch Cable | In Stock | £3.50 |
StarTech.com 0.5m Green Cat6 Patch Cable | In Stock | £3.47 |
StarTech.com 0.5m Orange Cat6 Patch Cable | In Stock | £3.47 |
StarTech.com 0.5m Purple Cat6 Patch Cable | In Stock | £3.67 |
StarTech.com 0.5m Red Cat6 Patch Cable | In Stock | £3.54 |
StarTech.com 0.5m White Cat6 Patch Cable | In Stock | £3.54 |
StarTech.com 0.5m Yellow Cat6 Patch Cable | In Stock | £3.67 |
