StarTech.com 0.5m Angled Micro USB Cable
Quicklinx: CY2WWS00 Mfr#: USBAUB50CMLA
Length: 50cm
20 In Stock
£4.71 ex VAT
£5.65 inc VAT
Charge newer phones and tablets efficiently, with up to 2.4 amps of power. This Micro-USB cable features 24 AWG wire to provide the full power you need to charge your mobile devices faster. The cable features a left-angled Micro-USB connector, so it's great for charging your mobile devices in a car, or for accessing your mobile device while it's connected to a car charger or computer.
Different phones and tablets require specific amounts of power to charge efficiently. While a phone may only require 1.0A of power, a tablet may need 2.4A.
This Micro-USB cable is designed to deliver full power to your mobile devices so that all of your devices can charge at the expected speed.
The left-angled Micro-USB connector lets you connect to ports that are difficult to reach, which is perfect for charging your car-mounted mobile devices. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way.
The angled connector also prevents the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection point, preventing unnecessary stress and damage to the cable and device port.
Replace the Micro-USB cable that came with your mobile device, or keep one as a spare while you're traveling so that your mobile devices are ready to use while you're on the road. The short 0.5 m/1.5 ft. cable length makes this an excellent solution for close-range connections and portable applications such as charging with a mobile charging bank, public charging stations or your laptop.
  • Durable design
    Crafted with a PVC jacket and aluminum mylar foil with braid, this USB to Micro USB cable is designed for durability and long-lasting performance, ensuring your connections remain robust and secure.
  • Enhanced connectivity
    Featuring a 90° left-angled Micro-USB Type-B connector and a nickel-plated USB Type-A connector, this 1 ft / 0.5m cable offers a reliable connection between devices, minimizing stress on the cable and ports for better longevity.
  • High compatibility
    Compliant with USB and USB 2.0 standards, this cable supports a wide range of devices, making it a versatile accessory for charging and data transfer needs.
StarTech.com Left Angle Micro USB Cable - 1 ft / 0.5m - 90 degree - USB Cord - USB Charger Cable - USB to Micro USB Cable (USBAUB50CMLA) - USB cable - Micro-USB Type B to USB - 50 cm
USB cable
Shielded
Length
50 cm
Connector
5 pin Micro-USB Type B - male - 90° left-angled
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
24/30
Plated Connector
Nickel
Length
50 cm
24 g
Connector
USB / USB 2.0, RoHS, WEEE
CY2W StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
CY2W StarTech.com 6 ft Micro-USB Charging Cable In Stock £7.11
CY2W StarTech.com 0.5m Angled Micro USB Cable In Stock £4.71
Length: 50cm
