StarTech.com 0.5m 1.6ft 10G SFP+ DAC Cable
Quicklinx: D9VHWS00 Mfr#: SFP10GPC05M
Length: 50cm
Colour: Black
£34.78 ex VAT
£41.73 inc VAT
Connect your MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com MSA Comp. SFP+ Direct-Attach Twinax Cable - 0.5 m (1.6 ft.) - 10GBase direct attach cable - 50 cm - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
50 cm
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
50 cm
36 g
Connector
SFP+ - latched
SFP+ - latched
FCC, RoHS, MSA
70 °C
D9VH StarTech.com 0.5m 1.6ft 10G SFP+ DAC Cable In Stock £34.78
D9VH StarTech.com 1m 3.3ft 10G SFP+ DAC Cable In Stock £36.85
D9VH StarTech.com 2m 6.6ft 10G SFP+ DAC Cable In Stock £43.00
D9VH StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £45.01
D9VH StarTech.com 5m 16.4ft 10G SFP+ DAC Cable In Stock £69.65
Length: 50cm
Colour: Black
Price Range Ex VAT: 0 - 50
