Minimize clutter and position your USB 3.0 Micro devices near your desktop or laptop computer easily, with a thin, flexible cable. Does your regular USB 3.0 cable lift or push against your external hard drive causing it to move around on your desk? Are you forced to arrange your desk according to how your cable decides to bend and rest?
The USB3AUB50CMS features a slim USB wire construction that makes it easier to install your USB 3.0 devices and enables you to place them as needed throughout your workspace. Plus, the thin Micro USB connector molding makes this a great cable for mobile USB 3.0 devices too - it lets you plug into your device without having to take it out of its case for every charge and sync.
Organize your desk and your office to match your needs. This durable, lightweight cable is approximately half the thickness of a regular USB 3.0 cable giving you the freedom to place your devices as needed and with minimal clutter. The flexible, thin cable also reduces strain on the connection and prevents damage to the USB 3.0 port on your device.
Plus, the short 0.5m/1.5-foot cable length makes this an excellent solution for close-range connections and portable applications (e.g. connecting a portable hard drive to your laptop).
Charge your mobile device in your car or sync with your laptop.
As well as being ideal for connecting to your desktop devices, this cable provides the perfect solution for charging and syncing your USB 3.0 Micro B-equipped phones and tablets.
The short cable design is just right for people on the move, for providing simple, tidy connections and it fits nicely inside your laptop or tablet carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a thin Micro USB connector molding that plugs into your device even while it's inside a protective case.
Data rates
Achieve transfer speeds of up to 5 Gbps with USB 3.0 compliance, suitable for syncing files and media. -
Durable construction
The cable features molded connectors that provide durability, ensuring long-lasting performance and resistance to wear. -
Flexible length
With a compact length of 0.5m, this cable is easy to carry and perfect for use in various settings. -
Strain relief feature
Designed with strain relief, this cable minimizes stress on connections, preventing damage and extending the lifespan. -
Nickel-plated connectors
The nickel-plated connectors provide excellent connectivity while protecting against corrosion.
- StarTech.com 0.5m 20in Slim USB 3.0 A to Micro B Cable M/M - Mobile Charge Sync USB 3.0 Micro B Cable for Smartphones and Tablets (USB3AUB50CMS) - USB cable - Micro-USB Type B to USB Type A - 50 cm
- USB cable
- Technology
- Shielded
- Molded, strain relief, 5 Gbps data rate
- Length
- 50 cm
- Connector
- 10 pin Micro-USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: S2510BU33PW, S251BMU3FP, S251BRU33, S251SMU33EP, SLSODDU33B, SM2NGFFMBU33, UNI251BMU33
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 26/32
- Plated Connector
- Nickel
- Length
- 50 cm
- Black
- Connector
- USB 3.0, RoHS
- Designed For
StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £8.06 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.39 |
StarTech.com 20" Slim Micro USB 3.0 Cable | In Stock | £7.49 |
