Extend SATA Data Connections by up to 30cm (12in). The SATAEXT30CM 0.3-meter (30cm) SATA Data Extension Cable enables you to extend the reach between internal SATA drive connections by up to 30 cm (11.81 in).
The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
- StarTech.com 0.3m SATA Extension Cable - 30cm 7 pin SATA Extension - 7 pin SATA Extension Cable - 7 pin SATA Extension cord - SATA extension cable - 30 cm
- Interface Speed
- Serial ATA 150/300/600
- Length
- 30 cm
- Connector
- 7 pin Serial ATA - plug
- Connector (Second End)
- 7 pin Serial ATA - receptacle
- Red
- Limited lifetime warranty
- Designed For
- P/N: SATA18RA1
- Storage Cable Type
- Interface Speed
- American Wire Gauge (AWG)
- 26
- Length
- 30 cm
- Red
- Connector
- RoHS
- Designed For
- P/N: SATA18RA1
StarTech.com 12in 22 Pin SATA Power and Data Extension Cable | In Stock | £7.59 |
StarTech.com 12in 15 pin SATA Power Extension Cable | In Stock | £8.16 |
