Product
StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M
Clearance!
Clearance
Last Few Remaining
Quicklinx: 9J44WS00 Mfr#: HDMM30CM
Length: 30cm
More than 50 in stock
£3.75 ex VAT
£4.50 inc VAT
Create Ultra HD connections between your High Speed HDMI-equipped devices, with reduced clutter. The HDMM30CM 30cm High Speed HDMI cable enables close-range connections of your HDMI-enabled devices, for situations where a longer cable would create clutter.
Plus, this short HDMI cable provides a portable solution that makes it perfect for carrying as a mobile accessory. When used with an HDMI to Micro or Mini HDMI adapter such as our HDMI 2-in-1 T-adapter, you can connect mobile devices such as your Smartphone, or Tablet to an HD display, or your Digital Camera to a laptop.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high-definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com 30cm Short High Speed HDMI Cable - Ultra HD 4k x 2k Cable M/M - HDMI cable - 30 cm
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
28
Length
30 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
HDMI cable
Double shielded
28
Jacket Material
PVC
Shielding Material
Length
30 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
9J44 StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro – F/M In Stock £6.47
9J44 StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Mini- F/M In Stock £7.95
9J44 StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £3.75
Length: 30cm
Price Range Ex VAT: 0 - 50
