Take your best shots yet. The 23MP camera features an Exmor RS for mobile sensor and 4K video recording to give you outstanding color and clarity, even in lowlight. The Xperia XA2 has a 5.2" full HD display with a borderless design, taking the screen right to the edge, and a perfect fit for your hand. Unlock with a simple touch thanks to the integrated fingerprint sensor, making sure only you can access your phone. Made with durable Corning Gorilla Glass, the Xperia XA2 display has a quality finish that offers uncompromised clarity.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Capture life's beauty
Take your best shots yet. The 23MP camera features an Exmor RS for mobile sensor and 4K video recording to give you outstanding color and clarity, even in lowlight. -
Super wide selfie
Fit lots of friends and more of the scenery into your selfie with a 120° super wide-angle 8MP camera. -
Designed to fit your hand
The Xperia XA2 has a 5.2" full HD display with a borderless design, taking the screen right to the edge, and a perfect fit for your hand. -
One-touch fingerprint sensor
Unlock with a simple touch thanks to the integrated fingerprint sensor, making sure only you can access your phone. -
Durable Corning Gorilla Glass
Made with durable Corning Gorilla Glass, the Xperia XA2 display has a quality finish that offers uncompromised clarity. -
The right settings for every song
The Smart Amplifier technology, backed up by ClearAudio+ and Clear Bass fine-tunes your sound so every note is clear. -
Rich sound quality
Listen to your music loud and clear with Smart Amplifier technology. -
Clear and balanced sound
ClearAudio+ delivers an immersive, enriching audio experience at a single touch. -
Powerful bass without distortion
Deep lows and bass notes have more impact with Clear BASS. -
A battery that's built to last
Enjoy your smartphone for longer with a high capacity battery. Smart charging technologies help keep your battery healthier for the long term. -
Packed with the power you need
Browsing the web or playing games? The Xperia XA2 uses the Qualcomm Snapdragon 630 Mobile Platform for a super-smooth and speedy performance. -
Learns and adapts to you
The Xperia XA2 uses smart technology to learn how you use your phone. Then Xperia Actions helps optimize your settings, while Xperia Tips gives you handy hints to get more from your phone.
- Sony XPERIA XA2 - black - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- H3113
- Display
- LCD display - 1920 x 1080 pixels - 5.2" - 424 ppi - TFT - Corning Gorilla Glass 4 (scratch resistant glass)
- FM radio
- Processor
- Qualcomm Snapdragon 630 2.2 GHz (8-core) - 64-bit
- Graphics Accelerator
- Qualcomm ADRENO 508
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Android 8.0 Oreo
- Main Camera
- 23 Megapixel - Exmor RS - wide-angle lens - 5x optical zoom - 120 mm - f/2.0 - focus: automatic
- Front Camera
- 8 Megapixel Exmor R - wide-angle lens - f/2.4 - focus free
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 2340 minutes
- Standby Time
- Up to 863 hours
- Black
- 70 mm x 9.7 mm x 142 mm
- 171 g
- Specific Absorption Rate (SAR)
- 1.07 W/kg (head) , 1.43 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- H3113
- Form Factor
- Touch
- Integrated Components
- FM radio
- 70 mm
- 9.7 mm
- 142 mm
- 171 g
- Body Colour
- Black
- SAR Value
- 1.43 W/kg (body), 1.07 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 8.0 Oreo
- Navigation
- GPS, GLONASS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
- Supported Email Protocols
- POP3, IMAP4
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 5, Band 7, Band 8, Band 20, Band 38
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2600
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
- WLAN Security
- WEP, WPA, WPA2, TKIP, AES, EAP SIM, EAP-TTLS/MSCHAPv2, EAP-AKA, EAP-TLS, PEAPv0/EAP-MSCHAPv2, PEAPv1/EAP-GTC
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, SPP, GAP, A2DP, AVRCP, HID, SAP, AVCTP, BNEP, GAVDP, PBAP, MAP, DIP, RFCOMM, GATT, HOGP, AVDP
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, pedometer, digital compass, magnetometer, motion sensor, geomagnetic sensor, Significant motion detector
- Security Devices
- Android Enterprise Recommended
- Additional Features
- TTY compatible, Text-to-Speech (text recognition), intelligent typing (SWIFTKEY), intelligent typing (Gesture), Wi-Fi Miracast, Screen mirroring, Wi-Fi Passpoint, Alarm Clock, handwriting recognition, Noise suppression, Qnovo Adaptive Charging, Battery Care, Smart Stamina, STAMINA Mode
Media Player
- Supported Digital Audio Standards
- WAV, AAC, MPEG 1 Audio, MPEG 2 Audio, MPEG 2.5 Audio, Ogg Vorbis, MP3, FLAC, AAC-LC, AAC +, OGG, eAAC+, MIDI, MPEG1 Layer3, apt-X, OTA, MP4, AMR-WB, AMR-NB, 3GPP, apt-X HD, SMF
- Supported Digital Video Standards
- MPEG-4, 3GP, H.264, H.263, WebM, VP8, VP9, 3GPP, H.264 MP, H.264 HP, H.265 Main
- Sound Enhancements
- Clear Audio+, Surround sound (VPT)
- Clock Speed
- 2.2 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
Graphics System
- RAM
- LPDDR4X SDRAM - 3 GB
- Internal Memory Capacity
- 32 GB
- User Memory
- 24 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Sensor Size
- 1/4"
- Sensor Name
- Sony Exmor R sensor
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.4
- Focus Adjustment
- Focus free
- Camera Modes
- SteadyShot
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
- Self-timer
Main Camera
- Sensor Resolution
- 23 Megapixel
- Sensor Size
- 1/2.3"
- Sensor Name
- Sony Exmor RS sensor
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.0
- Min Focal Length
- 120 mm
- Focus Adjustment
- Automatic
- Optical Zoom
- 5x
- Camera Modes
- Slow motion video, SteadyShot, low-light shots
- Light Source
- LED flash
- Video Resolutions
- 3840 x 2160 (4K), 1920 x 1080 (1080p) at 30 fps
- Quick Launch, Quick Capture, Hybrid Auto focus, Touch Capture, Stereo Audio Recording, geotagging, 5x Clear Image Zoom
Display
- LCD display
- Technology
- TFT
- Diagonal Size
- 5.2"
- Display Resolution
- Display Format
- Full HD
- Pixel Density
- 424 ppi
- Max Brightness
- 500 cd/m²
- Colour Depth
- 16.7 million colours
- Protection
- 2.5D curved glass, Image Enhance Technology
- Connector Type
- Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
- Technology
- Lithium Ion
- Capacity
- 3300 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 3.0
- Talk Time
- 2340 minutes
- Standby Time
- 863 hours
- Run Time Details
- Talk (GSM): up to 2340 min , Standby (GSM): up to 863 hrs , Talk (3G): up to 1740 min , Standby (3G): up to 991 hrs , Standby (LTE): up to 1185 hrs , Playback (MP3 (via headset)): up to 124 hrs , Playback (Full HD video (H.264)): up to 22 hrs
- Included Accessories
- Power adapter
- Limited warranty - 2 years
