With its impressive 21:9 wide 6.2" display, sleek design, multi-window functionality, and triple camera, the Xperia L4 lets you do so much more with your smartphone.
A comfortable fit
The Xperia L4 may have a large 6.2" display but it still fits in your hand perfectly, thanks to its sleek 21:9 wide aspect ratio, clean design, and slender form. -
Made for multi-tasking
The multi-window option on the 21:9 Wide display lets you easily split the screen into two separate windows and run different apps on each one. It's perfect for multi-tasking - for example, messaging on one window while watching a video on the other. -
See more, scroll less
The 21:9 Wide 6.2" display offers a greater viewable screen area for web browsing, reading, maps, video, messaging, and more. -
Easy one-handed operation
Despite its large 6.2" display, you can easily operate the Xperia L4 with one hand. The mini display feature puts everything within easy reach while Side sense gives you fast, intuitive access to all your apps. -
Big screen entertainment
The cinematic aspect ratio of the 21:9 Wide 6.2" display takes you deeper into movies, TV shows, games and more. -
Triple camera for triple the fun
Get creative with a triple camera featuring 26mm wide-angle, 17mm ultra-wide-angle, and a depth camera for beautiful bokeh effects. -
Broaden your horizons
The versatile wide-angle option covers most shooting situations but if you want to capture wider scenes, switch to ultra-wide-angle. -
Get creative with bokeh
Create beautiful photographs in which the background is defocused for artistic bokeh effects. -
Shoot in different formats
Multi-aspect shooting, including a cinematic 21:9 aspect ratio, lets you film or take photos in your favorite format in any situation. -
Long lasting battery
With a long lasting 3,580mAh battery, the Xperia L4 gives you all the power you need to stay connected. -
Fast charging when you need it
The Xperia L4 is compatible with the optional Fast Charger (UCH32C), so you can quickly top up when you're low on power. -
Powerful performance at your fingertips
A powerful processor, coupled with Wi-Fi and fast 4G for uploads and downloads, makes light work of apps, movies, games and more.
- Sony XPERIA L4 - black - 4G smartphone - 64 GB - GSM
- Product Type
- 4G smartphone
- Display
- LCD display - 1680 x 720 pixels - 6.2" - 21:9
- Processor
- MediaTek MT6762
- Memory
- RAM 3 GB / 64 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Operating System
- Android 9.0 Pie
- Main Camera
- 13 Megapixel - wide-angle lens 26 mm - f/2.0
- Second Camera
- 5 Megapixel - ultra wide-angle lens 17 mm - f/2.2
- Third Camera
- 2 Megapixel - f/2.4 - depth camera
- Front Camera
- 8 Megapixel f/2.0
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi, Bluetooth
- Security Devices
- Fingerprint reader (side)
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Black
- 71 mm x 8.7 mm x 159 mm
- 178 g
- Specific Absorption Rate (SAR)
- 0.59 W/kg (head) , 0.91 W/kg (body) , 1.03 W/kg (hotspot)
- 2-year warranty
- Product Type
- Smartphone
- Form Factor
- Touch
- 71 mm
- 8.7 mm
- 159 mm
- 178 g
- Body Colour
- Black
- SAR Value
- 0.91 W/kg (body), 1.03 W/kg (hotspot), 0.59 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Navigation
- GPS, A-GPS, GLONASS
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 5, Band 7, Band 8, Band 20, Band 40
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2300
- NFC, IEEE 802.11a/b/g/n, Bluetooth 5.0
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Security Devices
- Additional Features
- Multitasking, Fast Charging, One Hand Mode
Media Player
- Supported Digital Audio Standards
- PCM, MP3, FLAC, AAC-LC, AAC +, eAAC+, MIDI, ALAC, OPUS, AMR-WB, AMR-NB, Vorbis, AAC-ELD
- Supported Digital Video Standards
- MPEG-4, H.264, H.263, VP8, VP9, H.265
- MediaTek
- Processor Number
- MT6762
- RAM
- 3 GB
- Internal Memory Capacity
- 64 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Sensor Size
- 1/4.0"
- Lens Aperture
- F/2.0
- Field of View (FoV)
- 78 degree(s)
- Special Effects
- HDR, Portrait selfie effects
- Light Source
- Display flash
Main Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Size
- 1/3"
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.0
- Min Focal Length
- 26 mm
- 76 degree(s)
- Digital Zoom
- 4x
- Special Effects
- HDR
- Camera Modes
- Panorama, Bokeh Mode
- Light Source
- LED flash
- Stereo Recording, video stabilisation, up to 10fps AF/AE
Second Camera
- Sensor Resolution
- 5 Megapixel
- Sensor Size
- 1/5"
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Min Focal Length
- 17 mm
- 117 degree(s)
Third Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Depth camera
Display
- LCD display
- Diagonal Size
- 6.2"
- Display Resolution
- 1680 x 720 pixels
- Display Format
- HD+
- Aspect Ratio
- 21:9
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3580 mAh
- USB Power Delivery
- Included Accessories
- Power adapter
- Limited warranty - 2 years
