Enjoy natural vocals, crystal clear sound and balanced tuning thanks to the Integrated Processor V1 and Digital Sound Enhancement Engine (DSEE), producing a high quality sound exactly as the artists intended. Tailor sound to your personal preference using the EQ settings on the Sony | Headphones Connect app. 360 Reality Audio Certified – optimise your experience by analysing your individual ear shape on the Sony | Headphones Connect app, and enjoy the ultimate immersive music experience.
Digital Noise Cancelling headphones. Dual Noise Sensor technology and the Integrated Processor V1 let you adapt sound to your liking, and with the Sony | Headphones Connect app, you can adjust the ambient sound across 20 different levels for when you’re on the move.
Stays comfortable, however long you listen. A lightweight, ergonomic construction makes the most of the 35 hour* battery life, so these wireless headphones stay comfortable for long periods of listening. *With Noise Cancelling ON.
The WH-CH720N has Multipoint Connection, easy button operation, and can even be controlled with your voice. And since connection is easy with Swift pair and Fast Pair, these Sony headphones are ideal for everyday use.
With Precise Voice Pickup Technology, Wind Noise Reduction Structure, and beamforming mics to pick up your voice, you will enjoy clearer calls and better conversations with these over ear headphones.
Tune the world out
Dual Noise Sensor technology and an Integrated Processor V1 take Noise Canceling to the next level. You can shut the world around you out and immerse yourself in the music. -
Whether you're working from home or relaxing with your favorite content, the WH-CH720N are ergonomically designed to be lightweight and comfortable, and with long-lasting battery life, you can wear them for longer without needing a break. -
Sound like the artists intended
Enjoy natural vocals, crystal-clear sound and balanced tuning thanks to the Integrated Processor V1 and Digital Sound Enhancement Engine (DSEE), producing a high-quality sound exactly as the artists intended. -
Improved technology, better calls
Precise Voice Pickup technology, a beamforming mic, and Wind Noise Reduction Structure will give you a clear and natural conversation throughout the call. -
Multipoint connectivity
For total convenience, these Bluetooth headphones can be paired with two Bluetooth devices at the same time. So when a call comes in, your headphones know which device is ringing and connects to the right one automatically.
- Sony WH-CH720N - headphones with mic - 3.5 mm jack
- Product Type
- Headphones - Bluetooth - wireless, wired - 3.5 mm jack
- Recommended Use
- Portable electronics
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- Digital Sound Enhancement Engine (DSEE), 360 Reality Audio
- Audio Specifications
- Frequency Response 7 - 20000 Hz - Sensitivity 108 dB
- Active Noise Canceling
- Microphone Operation Mode
- Beamforming
- Controls
- Volume, voice assistant, play/pause, skip track
- Intelligent Assistant
- Alexa, Google Assistant - direct
- Product Type
- 192 g
- White
- Body Material
- Recycled plastic
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Dynamic
- Wireless, wired
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- Active Noise Cancelling Technology
- Ambient Sound Mode / Dual Noise Sensor
- 7 - 20000 Hz
- Sensitivity
- 108 dB
- Diaphragm
- 30 mm
- Adjustable Headband
- Simultaneously Connectable Devices Qty
- 2
- Processor V1, Automatic Wind Noise Reduction, Precise Voice Pickup Technology, adaptive mode, MultiPoint Technology, Google Fast Pair, Microsoft Swift Pair
Microphone
- Form Factor
- Built-in
- Beamforming
Remote Control
- Controls
- Connector Type
- USB (power only) (USB Type-C) , Headphones (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
Cable
- Detachable Cable
- Cable Length
- 1.2 m
- Plated Connector
- Gold
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Voice Controlled
- Direct
- Included Accessories
- USB-C cable, 3.5 mm audio cable
- Cable Details
- Headphones cable - detachable - 1.2 m , USB-C cable - detachable
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 50 hour(s)
- Run Time Details
- Continuous talk (noise cancelling ON / Bluetooth): up to 35 hours , Continuous playback (noise cancelling ON / Bluetooth): up to 35 hours , Continuous talk: up to 40 hours , Continuous playback: up to 50 hours
- Recharge Time
- 3.5 hour(s)
