Sony WH-CH720N Noise Cancelling Headphones Black
Quicklinx: HX9BWS00 Mfr#: WHCH720NB.CE7
Type: Headphones
Connectivity: Wireless, Wired
Colour: Black
43 In Stock
£74.17 ex VAT
£89.00 inc VAT
  • Enjoy natural vocals, crystal clear sound and balanced tuning thanks to the Integrated Processor V1 and Digital Sound Enhancement Engine (DSEE), producing a high quality sound exactly as the artists intended. Tailor sound to your personal preference using the EQ settings on the Sony | Headphones Connect app. 360 Reality Audio Certified – optimise your experience by analysing your individual ear shape on the Sony | Headphones Connect app, and enjoy the ultimate immersive music experience.
  • Digital Noise Cancelling headphones. Dual Noise Sensor technology and the Integrated Processor V1 let you adapt sound to your liking, and with the Sony | Headphones Connect app, you can adjust the ambient sound across 20 different levels for when you’re on the move.
  • Stays comfortable, however long you listen. A lightweight, ergonomic construction makes the most of the 35 hour* battery life, so these wireless headphones stay comfortable for long periods of listening. *With Noise Cancelling ON.
  • The WH-CH720N has Multipoint Connection, easy button operation, and can even be controlled with your voice. And since connection is easy with Swift pair and Fast Pair, these Sony headphones are ideal for everyday use.
  • With Precise Voice Pickup Technology, Wind Noise Reduction Structure, and beamforming mics to pick up your voice, you will enjoy clearer calls and better conversations with these over ear headphones.
  • Tune the world out
    Dual Noise Sensor technology and an Integrated Processor V1 take Noise Canceling to the next level. You can shut the world around you out and immerse yourself in the music.
    Whether you're working from home or relaxing with your favorite content, the WH-CH720N are ergonomically designed to be lightweight and comfortable, and with long-lasting battery life, you can wear them for longer without needing a break.
  • Sound like the artists intended
    Enjoy natural vocals, crystal-clear sound and balanced tuning thanks to the Integrated Processor V1 and Digital Sound Enhancement Engine (DSEE), producing a high-quality sound exactly as the artists intended.
  • Improved technology, better calls
    Precise Voice Pickup technology, a beamforming mic, and Wind Noise Reduction Structure will give you a clear and natural conversation throughout the call.
  • Multipoint connectivity
    For total convenience, these Bluetooth headphones can be paired with two Bluetooth devices at the same time. So when a call comes in, your headphones know which device is ringing and connects to the right one automatically.
Sony WH-CH720N - headphones with mic - 3.5 mm jack
Headphones - Bluetooth - wireless, wired - 3.5 mm jack
Recommended Use
Portable electronics
Headphones Form Factor
Full size
Wireless, wired
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Digital Sound Enhancement Engine (DSEE), 360 Reality Audio
Audio Specifications
Frequency Response 7 - 20000 Hz - Sensitivity 108 dB
Active Noise Canceling
Microphone Operation Mode
Beamforming
Controls
Volume, voice assistant, play/pause, skip track
Intelligent Assistant
Alexa, Google Assistant - direct
192 g
Body Material
Recycled plastic
Recommended Use
Max Operating Distance
10 m
Audio Output
Full size
Headphones Cup Type
Closed
Dynamic
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC
Bluetooth Version
Bluetooth 5.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Sound Effects
Active Noise Cancelling Technology
Ambient Sound Mode / Dual Noise Sensor
Frequency Response
7 - 20000 Hz
Sensitivity
108 dB
Diaphragm
30 mm
Adjustable Headband
Simultaneously Connectable Devices Qty
2
Processor V1, Automatic Wind Noise Reduction, Precise Voice Pickup Technology, adaptive mode, MultiPoint Technology, Google Fast Pair, Microsoft Swift Pair
Microphone
Built-in
Beamforming
Remote Control
Controls
Connector Type
USB (power only) (USB Type-C) , Headphones (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
Cable
Detachable Cable
Cable Length
1.2 m
Plated Connector
Gold
Internet of Things (IoT)
Voice Controlled
Direct
USB-C cable, 3.5 mm audio cable
Cable Details
Headphones cable - detachable - 1.2 m , USB-C cable - detachable
Headphone battery rechargeable
Run Time (Up To)
50 hour(s)
Run Time Details
Continuous talk (noise cancelling ON / Bluetooth): up to 35 hours , Continuous playback (noise cancelling ON / Bluetooth): up to 35 hours , Continuous talk: up to 40 hours , Continuous playback: up to 50 hours
Recharge Time
3.5 hour(s)
Type: Headphones
Connectivity: Wired
Colour: Black
Brand: Sony
