Sony WH-CH520 Over Ear Wireless Headphones White
Quicklinx: HX99WS00 Mfr#: WHCH520W.CE7
Type: Headphones
Connectivity: Wireless
Colour: White
Colours:
£32.50 ex VAT
£39.00 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
  • The Digital Sound Enhancement Engine (DSEE) restores your music with high frequency and gradual fade out sound for a more authentic performance. You can even tailor to your own taste with EQ settings on the Sony | Headphones Connect app, for a personalised listening experience.360 Reality Audio Certified – optimise your experience by analysing your individual ear shape on the Sony | Headphones Connect app, and enjoy the ultimate immersive music experience.
  • With up to 50 hours of battery life, you can listen to your favourite music without worrying about running out of charge. And, if your headphone battery is running low, a 3-minute quick-charge can give you 1.5 hours of listening time. With an adjustable headband, soft earpads and lightweight design, you can find your perfect fit and stay comfortable for longer with these on ear headphones.
  • The WH-CH520 has Multipoint Connection, easy button operation, and can even be controlled with your voice. And since connection is easy with Swift Pair and Fast pair, these Sony headphones are ideal for everyday use.
  • Easily answer calls with one click of the buttons on the earcups, so there’s no need to take your phone from your pocket. With a high-quality built-in microphone and noise suppression processing, the WH-CH520 collects sound and reduces ambient noise during calls, so you can make clear calls even in noisy environments.
  • A listening experience just for you
    Digital Sound Enhancement Engine (DSEE) restores the harmonics and liveliness lost during typical music compression, for a more authentic performance.
  • Stay powered up for days
    With ultra-long battery life, you can listen to your favorite music without worrying about running out of charge. And, if your headphones battery is running low, a three-minute quick-charge can give you long listening time.
  • Crystal-clear calls
    A built-in microphone provides you with hands-free calling, and it also works just as well for joining an online class or work meeting.
  • Multipoint connectivity
    For total convenience, these Bluetooth headphones can be paired with two Bluetooth devices at the same time. So when a call comes in, your headphones know which device is ringing and connects to the right one automatically.
  • Designed for all-day comfort
    Not only is the design stylish, but it's also crafted with ease-of-use in mind. The lightweight build and swivel earcups gently slip on and off, while the adjustable headband, cushion and soft ear pads give you all-day comfort.
Sony WH-CH520 - headphones with mic
Type: Headphones
Colour: White
Brand: Sony
Stock Status: While stocks last
Stock Status: Clearance
