Sony WH-1000XM4 Wireless Headphones - Silver
Quicklinx: HYJXWS00 Mfr#: WH1000XM4S.CE7
Type: Over-Ear
Connectivity: Bluetooth
Colour: Silver
Colours:
11 left in stock
£157.50 ex VAT
£189.00 inc VAT
Express delivery Order within the next 10 hours for delivery on Tuesday
Sony's intelligent industry-leading noise-canceling headphones with premium sound elevate your listening experience with the ability to personalize and control everything you hear. Get up to 30 hours of battery life with quick charging capabilities, enjoy an enhanced Smart Listening feature set, and carry conversations hands-free with speak-to-chat.
  • Industry-leading digital noise cancellation
    Industry-leading noise cancellation technology means you hear every word, note, and tune with incredible clarity, no matter your environment. Additional microphones also assist in isolating sound while talking on the phone, resulting in improved phone call quality and the reduction of even more high and mid frequency sounds.
  • Ambient sound control
    Adjust ambient sound with the Sony Headphones Connect app to cancel noise while still allowing through essential sounds, like transport announcements, when you're listening on the move.
  • Proprietary technology for premium sound
    LDAC transmits approximately three times more data (at the maximum transfer rate of 990 kbps) than conventional Bluetooth audio, allowing you to enjoy high-resolution audio content in exceptional quality, as close as possible to that of a dedicated wired connection. Powered by DSEE Extreme technology, the 40mm drivers with Liquid Crystal Polymer (LCP) diaphragms are Hi-Res Audio Compatible, reproducing a full range of frequencies up to 40 kHz.
  • Real-time restoration of all your compressed files
    Using Edge-AI (Artificial Intelligence) co-developed with Sony Music Entertainment, DSEE Extreme (Digital Sound Enhancement Engine) upscales compressed digital music files in real time. Dynamically recognizing instrumentation, musical genres, and individual elements of each song, such as vocals or interludes, it restores the high-range sound lost in compression for a richer, more complete listening experience.
  • All-day power with quick charging
    The WH-1000XM4 headphones are made to last all day and then some, whether you're focused on your work or flying around the globe. Up to 30 hours of battery life on a single charge keeps you listening instead of charging. Low on battery? No problem - 10 minutes of charge time gives you an amazing up to 5 hours of playback.
  • Touch control
    Change the track, turn the volume up or down, activate your phone's voice assistant, and take or make calls by tapping or swiping the panel with your fingertip.
  • Clear hands-free calling
    Conversation flows freely with easy, hands-free calling. Leave your phone where it is, just speak with a double tap. Thanks to Precise Voice Pickup Technology, which combines five built-in microphones with advanced audio signal processing, WH-1000XM4 delivers clearer voice quality to the other person on the phone. Precise voice pickup technology implemented in WH-1000XM4 optimally controls the five microphones built into the headphones and performs advanced audio signal processing to pick up your voice clearly and precisely for hands-free calls.
  • Multipoint connection
    For total convenience, the WH-1000XM4 headphones can be paired with two Bluetooth devices at the same time. So, when a call comes in, your headphones know which device is ringing and will automatically connect to the right one. You'll also be able to quickly and smoothly switch your headphones to either of the two devices at the touch of a button.
  • Adaptive Sound Control automatically adjusts to your location and behavior
    Adaptive Sound Control is a smart function that can learn to recognize locations you frequently visit, such as your workplace or favorite café, and tailor sound for the ideal listening experience. In addition, it automatically detects what you're up to - for example, walking, waiting, or traveling - then adjusts ambient sound settings to best suit the situation.
  • Wearing comfort
    WH-1000XM4 headphones blend sophisticated styling with exceptional comfort. Super-soft, pressure-relieving earpads in foamed urethane evenly distribute pressure and increase ear/pad contact for a stable fit. And with a lighter- weight design, you'll barely notice you're wearing them.
Sony WH-1000XM4 - headphones with mic
Headphones - Bluetooth - wireless, wired - NFC - 3.5 mm jack
Recommended Use
Portable electronics
Additional Functions
Touch panel
Silver
Headphones Form Factor
Full size
Foldable
Wireless, wired
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.0
Sound Effects
Digital Sound Enhancement Engine Extreme (DSEE Extreme), Adaptive Sound Control, 360 Reality Audio
Diaphragm Type
Aluminium coated LCP
Active Noise Canceling
Microphones Included
5
Controls
Volume control, ANC on/off
Intelligent Assistant
Google Assistant, Alexa
Touch panel
Silver
Earpad Material
Urethane foam
Recommended Use
Touch control
Max Operating Distance
10 m
High-Resolution Audio
Audio Output
Full size
Headphones Cup Type
Closed
Foldable
Dynamic
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, LDAC
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Serial Copy Management System (SCMS-T)
Sound Effects
Active Noise Cancelling Technology
Ambient Sound Mode / Dual Noise Sensor
Diaphragm
Aluminium coated LCP - 40 mm
Magnet Material
Neodymium
HD Noise Canceling Processor QN1, Speak-to-chat technology, Precise Voice Pickup Technology, Quick Attention function, CCAW coil, Smart Listening Technology, Personal Noise Cancelling Optimiser, Atmospheric Pressure Optimising
Microphone
Built-in
5
Remote Control
Controls
Tracking
Sensors
Proximity sensor, touch sensor
Connector Type
USB (power only) , Bluetooth , Headphones (mini-phone stereo 3.5 mm)
Cable
Detachable Cable
Internet of Things (IoT)
Carrying case, in-flight plug adapter, headphones cable (1.2 m), USB-C cable (0.2m)
Cable Details
USB-C charge cable - detachable , Audio cable - OFC - L shaped / mini-phone stereo 3.5 mm - 1.2 m
Headphone battery rechargeable
Run Time (Up To)
38 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on): up to 30 hours , Continuous playback (active noise-cancelling off): up to 38 hours
Standby Time
200 hours
Recharge Time
3 hour(s)
Type: Over-Ear
Colour: Silver
Brand: Sony
Stock Status: While stocks last
Stock Status: Clearance
