The WF-1000XM5 features cutting-edge technology to deliver premium sound quality and the best noise-canceling performance on the market.
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
The better noise canceling
The best noise canceling earbuds, with two proprietary processors that cancel more external noise than ever, a high-performance driver unit, dual feedback microphones and noise isolation earbud tips. -
Astonishing sound quality
The specially designed driver unit, Dynamic Driver X, provides wide frequency reproduction, so you can enjoy richer, more detailed vocals. -
Small and beautifully designed
With improved glossy texture and luxurious feel, these headphones fit comfortably in your ear and come with a smaller case, so they fit even more sleekly in your pocket. -
Sony's better ever call quality
Noise reduction algorithms developed with AI machine learning suppress ambient noise and ensure the person on the other end of the phone can hear your voice clearly even in noisy situations. -
Multipoint connection
For total convenience, the WF-1000XM5 can be paired with two Bluetooth devices simultaneously so, when a call comes in, your headphones can automatically connect to the right one. With the multipoint connection you can quickly switch to a ringing device, then back by simply resuming playback on the other device. -
Adjusts to the world around you
Adaptive Sound Control senses where you are and what you're doing, then uses AI to change ambient sound settings for the ideal listening experience. Over time, it will learn your behavior, recognize locations you visit often, and tailor the sound to suit your location. -
Talk and hear only ambient sound
You can set Speak-to-Chat to pause the music as soon as you start speaking to someone, so you can hear just ambient sound and conduct a conversation - handy if you want to keep your headphones on or your hands are full. Once your chat is over, your music will start playing automatically. -
Water resistant for everyday use
With an IPX4 water resistance rating, splashes and sweat won't stop these headphones - so you can keep moving to the music.
- Sony WF-1000XM5 - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.3
- Sound Effects
- Digital Sound Enhancement Engine Extreme (DSEE Extreme), Ambient Sound Mode, 360 Reality Audio
- Audio Specifications
- Frequency Response 20 - 40000 Hz
- Active Noise Canceling
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Charging case: 6.46 cm x 2.65 cm x 4 cm / 39 g , Earphone: 5.9 g
- Black
- Recommended Use
- Protection
- Water-resistant
- Max Operating Distance
- 10 m
- High-Resolution Audio
Audio Output
- In-ear
- Dynamic
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, LDAC, LC3
- Bluetooth Version
- Bluetooth 5.3
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Telephony and Media Audio Profile (TMAP)
- Sound Effects
- Active Noise Cancelling Technology
- Multi Noise Sensor technology
- 20 - 40000 Hz
- Diaphragm
- 8.4 mm
- Bone Conducting Technology
- Precise Voice Pickup Technology, Google Fast Pair, Quick Attention function
Microphone
- Form Factor
- Built-in
Tracking
- Sensors
- Head tracking sensor, bone sensor
- Connector Type
- Bluetooth
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Voice Controlled
- Indirect
- Included Accessories
- Charging case, 3 sizes of noise isolation earbud tips
- Cable Details
- USB-C charge cable - detachable - 20 cm
- IPX4
- Battery
- Headphone battery rechargeable - wireless charging
- Wireless Charging Standards
- Qi
- Run Time (Up To)
- 12 hour(s)
- Run Time Details
- Continuous playback (noise cancelling OFF): up to 12 hours , Continuous playback (noise cancelling ON): up to 8 hours , Continuous talk (noise cancelling OFF): up to 7 hours , Continuous talk (noise cancelling ON): up to 6 hours
