Discover the freedom of Bluetooth connectivity with the compact WF-C500 truly wireless earbuds, combining excellent sound with great battery life, personalization, and IPX4 water resistance for music that goes anywhere.
More delightful listening experience
With our Digital Sound Enhancement Engine (DSEE), high frequency sound and fine fade-out sound are restored to the track for a more authentic listening experience. You can also tailor music to your own taste using the EQ setting on the Sony | Headphones Connect app.
Make your music more natural
When an original music source is compressed, it loses the high-frequency elements that add detail and richness to a track. Our Digital Sound Enhancement Engine (DSEE) faithfully restores these to produce high-quality sound that’s closer to the original recording.
Your sound, just how you like it
Tailor sound to your personal preference. Choose from a variety of presets to match sound quality with the genre of music you're listening to. Or create and save your own presets using the EQ Custom feature on the Sony¦Headphones Connect app.
Small and light, a great fit
Designed small, these buds fit securely and comfortably in your ears. The rounded shape without edges makes them a pleasure to wear, leaving you free to focus on what matters – your music.
Ergonomic Surface Design
Since introducing the world’s first in-ear headphones in 1982 (MDR-E252), we’ve surveyed huge amounts of data relating to ear shapes from around the world. The WF-C500 headphones are the product of that research, combining a shape that matches the ear cavity with a new ergonomic surface design for a more stable fit.
Go anywhere, pocket-sized case
The cylindrical charging case is extremely small and easy to carry around in a pocket or bag so you can take your earbuds everywhere you go. Its translucent lid with a texture like frosted glass gives the case a stylish, luxurious look and feel.
Easy button operation
The buttons on the WF-C500 headphones not only let you play, stop, or skip through tracks and adjust the volume – they also offer an easy way to access your smartphone’s voice assistant and make and receive calls hands-free.
Easier, clearer hands-free calling
Conversation flows freely with easy hands-free calling, now clearer than ever with a high-quality built-in microphone. You won’t even have to take your phone out of your pocket.
Voice Assistant compatible
One simple button press connects you instantly to your smartphone’s voice assistant so you can find directions, play music, communicate with contacts and so much more.
Listen all day, charge in minutes
Enjoy up to 20 hours of listening thanks to the handy charging case. And if you need to top up in a hurry, 10 minute quick charging gives you up to an hour of extra play time.
*Stable, reliable Bluetooth® connectivity *
A Bluetooth® chip, which transmits sound to left and right ears simultaneously, coupled with optimised antenna design, ensures a stable connection and outstanding listening. Low audio latency makes for enjoyable viewing too.
Sustainability in mind
Our products are not only designed to be stylish but also with the environment in mind. No plastic is included in the packaging material for the WF-C500, reflecting Sony’s commitment to reducing the environmental impact of our products and practices.
Ergonomic surface design
The WF-C500 headphones are the product of the research, combining a shape that matches the ear cavity with an ergonomic surface design for a more stable fit. -
Customize your sound
With the Digital Sound Enhancement Engine (DSEE), high-frequency sound and fine fadeout sound are restored to the track for a more authentic listening experience. -
Make music more natural
When an original music source is compressed, it loses the high-frequency elements that add detail and richness to a track. The Digital Sound Enhancement Engine (DSEE) faithfully restores these to produce high-quality sound that's closer to the original recording. -
Designed small, these buds fit securely and comfortably in your ears. The rounded shape without edges makes them a pleasure to wear, leaving you free to focus on what matters - your music. -
The buttons on the WF-C500 headphones not only let you play, stop, or skip through tracks and adjust the volume - they also offer an easy way to access your smartphone's voice assistant and make and receive calls handsfree. -
Stable, reliable Bluetooth connectivity
A Bluetooth chip, which transmits sound to left and right ears simultaneously, coupled with optimized antenna design, ensures a stable connection and outstanding listening. Low audio latency makes for enjoyable viewing.
 - Sony WF-C500 - true wireless earphones with mic
- Product Type
 - True wireless earphones - Bluetooth
- Compatibility
 - Windows
 - Black
- Headphones Form Factor
 - In-ear
- Wireless Technology
 - Bluetooth
- Headphones Technology
 - Dynamic
- Bluetooth Version
 - Bluetooth 5.0
- Sound Effects
 - Digital Sound Enhancement Engine (DSEE), 360 Reality Audio
- Audio Specifications
 - Frequency Response 20 - 20000 Hz
- Controls
 - Volume, voice assistant
 - 1-year warranty
- Product Type
 - True wireless earphones - Bluetooth - wireless
- Compatibility
 - Windows
- Dimensions & Weight Details
 - Earbud: 5.4 g , Charging case: 8 cm x 3.09 cm x 3.49 cm / 35 g
 - 5.4 g
 - Black
- Protection
 - Splashproof, sweat-resistant, IPX4
- Max Operating Distance
 - 10 m
Audio Output
 - In-ear
 - Dynamic
- Connectivity Technology
 - Wireless
 - Bluetooth
- Bluetooth Audio Codec
 - SBC, AAC
- Bluetooth Version
 - Bluetooth 5.0
- Bluetooth Profiles
 - Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Effects
 - 20 - 20000 Hz
- Diaphragm
 - 5.8 mm
- Magnet Material
 - Neodymium
Microphone
- Form Factor
 - Built-in
Remote Control
- Controls
- Connector Type
 - USB (power only) (USB Type-C)
- Included Accessories
 - Charging case
- Cable Details
 - USB-C charge cable - detachable
- Battery
 - Headphone battery rechargeable
- Run Time (Up To)
 - 10 hour(s)
- Run Time Details
 - Continuous playback: up to 10 hours , Continuous talk: up to 5 hours
- Recharge Time
 - 2.5 hour(s)
 - Limited warranty - parts and labour - 1 year
