An exceptional listening experience that's tailored just for you. The WF-1000XM4 truly wireless headphones take advanced noise canceling and audio quality to the next level. Made to fit every ear, they offer a personalized experience that adjusts to every situation.
Industry-leading noise cancellation – now even better
Everything in the WF-1000XM4 headphones has been designed from the ground up. Like our new Integrated Processor V1, specially developed by Sony, that cancels more noise than ever, a new driver unit with more performance, noise sensing microphones, and innovative Noise Isolation Earbud Tips with a more stable fit.
High performance dual noise sensor microphones
Two noise sensing microphones per ear – one feed-forward and one feed-back – on the surface of the headphones catch more of the ambient sounds of your surroundings, whether it’s in-flight noise, city traffic or office chatter.
New 6mm driver unit
A newly designed 6mm driver unit, featuring a 20% increase in magnet volume and the high compliance diaphragm, gives you improved performance in low frequencies. It also enhances noise cancelling by generating a high-precision cancellation signal to the low frequency range.
Newly developed Noise Isolation Earbud Tips feature a unique polyurethane foam material. Soft and elastic, it maximises the surface contact area between the earbud tip and the ear canal, eliminating gaps to insulate sound and reduce noise. It also improves adhesion to the ear canal for a more stable fit, making the WF-1000XM4 headphones easy to wear.
Minimising wind noise
Even on windy days you’ll stay totally immersed. Automatic Wind Noise Reduction mode detects when it’s windy and automatically suppresses it.
Hear more of what’s around you
In Ambient Sound mode, the WF-1000XM4 headphones capture more of the sound around you than ever before, which means you get a more natural listening experience and stay connected to your environment.
Discover freedom
See how the WF-1000XM4 earphones combine advanced noise canceling with exceptional audio performance and personalized, smart features that adjust to your location. -
Specially developed by Sony, the Integrated Processor V1 takes the noise canceling performance of the acclaimed QN1e chip and goes even further. Improved noise canceling performance and Bluetooth "System on Chip" technology delivers the industry's highest level of noise canceling yet uses less power. -
Two noise sensing microphones per ear - one feed-forward and one feed-back - on the surface of the headphones catch more of the ambient sounds of your surroundings, whether it's in-flight noise, city traffic or office chatter. -
6mm driver unit
A newly designed 6mm driver unit, featuring a 20% increase in magnet volume, gives you improved performance in low frequencies. It also enhances noise canceling by generating a high-precision cancellation signal to the low frequency range. -
Newly developed Noise Isolation Earbud Tips feature a unique polyurethane foam material. Soft and elastic, it maximizes the surface contact area between the earbud tip and the ear canal, eliminating gaps to insulate sound and reduce noise. It also improves adhesion to the ear canal for a more stable fit, making the WF-1000XM4 headphones easy to wear. -
Minimizing wind noise
Even on windy days you'll stay totally immersed. Automatic Wind Noise Reduction mode detects when it's windy and automatically suppresses it. -
Hear more of what's around you
In Ambient Sound mode, the WF-1000XM4 headphones capture more of the sound around you than ever before, which means you get a more natural listening experience and stay connected to your environment. -
Adaptive Sound Control automatically adjusts to your situation
Adaptive Sound Control is a smart function that senses where you are and what you're doing, then adjusts ambient sound settings for the ideal listening experience. -
Headphones that get to know you
You can opt to have Adaptive Sound Control learn to recognize places that you frequently visit, like your office, the gym, or a favorite café, and tailor sound to suit the situation.
- Sony WF-1000XM4 - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.2
- Sound Effects
- Digital Sound Enhancement Engine Extreme (DSEE Extreme), Ambient Sound Mode, Adaptive Sound Control, 360 Reality Audio
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Active Noise Canceling
- Microphone Operation Mode
- Omni-directional
- Microphones Included
- 2
- Controls
- Tap control
- Intelligent Assistant
- Google Assistant, Alexa
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Earphone: 7.3 g
- 41 g
- Black
- Earpad Material
- Polyurethane foam
- Recommended Use
- Protection
- Water-resistant
Audio Output
- In-ear
- Dynamic
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, LDAC
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Serial Copy Management System (SCMS-T)
- Sound Effects
- Active Noise Cancelling Technology
- Digital Noise Cancelling technology (DNC)
- 20 - 20000 Hz
- Diaphragm
- 6 mm
- Magnet Material
- Neodymium
- Precise Voice Pickup Technology, Quick Attention function, Microsoft Swift Pair, Processor V1, Automatic Wind Noise Reduction, Speak-to-Chat
Microphone
- Form Factor
- Built-in
- Omni-directional
- 2
Remote Control
- Controls
- Tap control
Tracking
- Sensors
- Proximity sensor, bone sensor
- Connector Type
- Bluetooth , USB (power only) (USB Type-C)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- USB-C to USB-A cable, 3 sizes of noise isolation earbud tips
- Cable Details
- USB-C charge cable - detachable
- IPX4
- Battery
- Headphone battery rechargeable - wireless charging
- Wireless Charging Standards
- Qi
- Run Time (Up To)
- 12 hour(s)
- Run Time Details
- Continuous playback (noise cancelling OFF): up to 12 hours , Continuous playback (noise cancelling ON): up to 8 hours , Continuous talk (noise cancelling OFF): up to 6 hours , Continuous talk (noise cancelling ON): up to 5.5 hours
- Recharge Time
- 1.5 hour(s)
