Sony VPLL-Z4025 Middle Focus Zoom Lens for FH300L / FW300L
Quicklinx: 9RN9WS00 Mfr#: VPLL-Z4025
£3,707.73 ex VAT
£4,449.27 inc VAT
The VPLL-Z4025 is a middle focus zoom lens for the larger venue projectors.
  • Versatile zoom capability
    Equipped with an optical zoom of 1.84, the Sony VPLL Z4025 lens offers flexible zoom capabilities, allowing for precise control over image size without compromising image quality. This feature is ideal for various projection distances, ensuring that your presentations and visuals are displayed perfectly, no matter the venue size.
  • Exceptional image clarity
    With a lens aperture range of f/2.2-3.1, the Sony VPLL Z4025 delivers exceptional image clarity and brightness. This range allows for optimal light transmission, ensuring that images are vivid and clear, even in environments with varying light conditions.
  • Adaptable throw ratio
    The Sony VPLL Z4025 features a throw ratio of 2.5-4.5:1, providing versatility in projector placement. This adaptable throw ratio means the lens can produce large images from a short distance, making it suitable for both small meeting rooms and larger conference halls without the need for extensive setup adjustments.
Sony VPLL-Z4025 - zoom lens - 64.59 mm - 124.11 mm
Lens System
Zoom lens
Intended For
Projector
Lens Aperture
F/2.2-3.1
Focal Length
Optical Zoom
1.84 x
Special Functions
Zoom
Length
24.3 cm
2.8 kg
VPL-FH300L, FHZ131, FHZ91, FW300L
Length
24.3 cm
14.8 cm
13.3 cm
2.8 kg
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Projector
Focal Length
Lens Aperture
F/2.2-3.1
Optical Zoom
1.84 x
Throw Ratio
2.5-4.5:1
Sony VPL-FH300L, FHZ131, FHZ91, FW300L
Brand: Sony
Price Range Ex VAT: £1500+
