Sony VPLL-FM22PK VPLL-FM22 + PKF500LA2 for FX500L
Quicklinx: 9RN0WS00 Mfr#: VPLL-FM22PK
The VPLL-FM22 is a 0.9:1 short throw lens designed specifically for the VPL-PX40 SuperBright LCD data projector. It is ideal for rear screen applications where space is limited. The throw distance can be calculated by multiplying the desired screen width times 0.9.
Sony VPLL-FM22PK - wide-angle lens - 18 mm
Lens System
Wide-angle lens
Intended For
Projector
Lens Aperture
F/2.0
Focal Length
18 mm
Focus Adjustment
Manual
Special Functions
Wide angle
Length
16.9 cm
0.95 kg
Length
16.9 cm
8.8 cm
8.8 cm
0.95 kg
Lens System
Wide-angle lens
Special Functions
Wide angle
Intended For
Projector
Focal Length
18 mm
Lens Aperture
F/2.0
Focus Adjustment
Manual
Projection Distance for a 100" Screen
1.8m
Throw Ratio
0.9:1
Lens adaptor
