Sony VPL-SX226 Short Throw Projector S Series 2800LM XGA
Quicklinx: C01LWS00 Mfr#: VPL-SX226
The wall-mountable short throw projector VPL-SX226 is suitable for using a projector with a white board. A short throw distance of 75 cm for an 80" screen is good for limited space in a classroom. The teacher can be free from the projector's glare and able to easily teach their students. By using this projector with an interactive white board the initial costs can be reduced.
This projector has a long-lasting lamp. The unique lamp dimming function by Sony reduces the lamp power usage and lamp power consumption. It's low TCO and usability means the user can enjoy bright images for a much longer time.
VPL-SX236 is a colorful and bright projector. Thanks to the 3LCD Sony "BrightEra ", the picture is colorful and the images are bright. And it also has vivid 2,800 lumen with XGA resolution. These specs are best for a classroom environment. It's easier for all of the students to see with this big screen size.
Smart connection with PC, Tablet and smartphone is also supported. The wireless presentation capability makes it simple to present files from your PC or smart phone/tablet.
  • Short throw distance
    The projector's short focal length lens allows a 80 inches image to be projected from a distance of only 75 cm from the screen. The presenter is not distracted by the projected image, and it's easier for the audience to see the projected image as on screen shadows from the presenter are minimized.
  • Advanced energy-saving features
    Advanced lamp technology enables a range of energy-saving features. Auto light dimming mode saves energy when the projector is left on without being used. Auto picture mode automatically adjusts light output to suit the projected scene. Touching a button on the remote mutes the picture temporarily, dramatically reducing power consumption.
  • Low TCO
    The unique lamp dimming function reduces lamp power usage and lamp power consumption. Its low total cost of ownership (TCO) and usability lets you enjoy bright images for a much longer time.
  • Eco mode key
    Just touch the Eco mode key on the projector or supplied remote commander to instantly access energy-saving settings.
  • 3LCD BrightEra technology
    The efficient 3LCD panel system is enhanced by advanced BrightEra technology by Sony. You'll see the difference with impressively bright, consistent, high resolution images with excellent color accuracy and impressive reliability.
  • Bright, clear images
    With a 2,800 lumen maximum light output, the VPL-SX226 delivers crisp, bright presentations that can be seen clearly in classrooms or meeting rooms. There's a choice of three brightness modes to suit any environment, from bright daylight to darkened rooms.
  • Networked presentations
    Project presentations from a networked PC or Mac. Present JPEG, PDF and other files wirelessly from a tablet or smartphone. Up to four users can project PC/Mac images simultaneously, while up to eight users can connect to one projector. The projector station for network presentation application for Windows/Mac is included. For tablet/smartphone use, an application is provided by Pixelworks, downloaded from the web.
  • Control and management from any networked PC
    Projector functions and status can be managed and monitored remotely from any networked PC, using the included Projector Station for Network Control application.
  • Present wirelessly
    Make presentations wirelessly from a portable or handheld device.
  • Remote control for iPhone/iPad/Android phone
    Download the free projector remote App and control the projector from anywhere in the room with your handheld device, with simple easy-to-read buttons on your phone or tablet.
  • USB media viewer
    Slip in a USB drive and display photos, images and graphics with no PC needed.
  • USB display for easy one-cable PC connection
    Present pictures and audio from a connected PC or Mac with just one USB cable you don't even need to install a software driver.
  • Customized input labels
    Define your own input labels like 'BD player', 'PC' and 'document camera', making it easier to see on screen what devices are connected and being used.
  • Stylish blend-in design
    The projector's smart, contemporary looks fit discreetly into any classroom, training suite or meeting room.
Sony VPL-SX226 - 3LCD projector - short-throw - LAN
3LCD projector
Built-in Devices
Speaker
Brightness (White)
2800 lumens
Brightness (Colour)
2800 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
Short-throw fixed lens
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
294 Watt
36.5 cm x 31 cm x 13.87 cm
4.4 kg
1-year warranty
3LCD projector
Built-in Devices
Speaker
Projector
Brightness (White)
2800 lumens
Brightness (Colour)
2800 lumens
Brightness (Reduced)
1600 lumens
Contrast Ratio
3000:1
Image Size
152 cm - 279 cm
Throw Ratio
0.46:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, Wireless Ready, Dynamic Mode, Auto Dimming Mode, USB Viewer, Eco Mode
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-7.5 / +7.5
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
Remote control
Power Source
AC
294 Watt
Power Consumption Stand by
0.5 Watt
36.5 cm
31 cm
13.87 cm
4.4 kg
Limited warranty - 1 year
20 - 80% (non-condensing)
30 dB
C01L C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
