Sony VPL-SW636C 1600 x 1200 RGB HDMI 3LCD Projector
Quicklinx: C058WS00 Mfr#: VPL-SW636C
Bright, high contrast widescreen projector for mid-size classrooms and meeting rooms: with easy installation, a wide range of enhanced interactivity functions and low ownership costs.
The VPL-SW636C Ultra Short Throw projector is ideal for classroom or corporate use, with simple, flexible installation, low ownership costs, enhanced interactivity and easy connection to other devices.
Present big, bright images over 2m across with the projector as little as 47cm from the screen or whiteboard, with less distracting glare and shadows.
Advanced 3LCD BrightEra™ panel technology by Sony ensures high contrast, widescreen WXGA images with excellent colour stability. The projector’s powerful 3,300 lumens colour light output ensures that presentations are always seen clearly, even in brightly-lit environments.
Seamless integration with school or office networks can be enhanced with an optional Wi-Fi module, letting students wirelessly share homework, images and graphics from PCs, smartphones and tablets. Learning’s made richer and more collaborative with dual pen interactivity, allowing teacher and pupil to write on screen simultaneously. In PC-free interactive mode, you don't even need a connected PC to write, draw and annotate on-screen presentations.
There’s a wide range of smart energy-saving features built in. An extra-long lamp replacement time of up to 10,000 hours minimises costs and reduces downtime in busy classrooms and offices. A newly-designed wall mount bracket makes installation easier in rooms with low ceilings.
  • Bright, clear images with maximum 3,300 lumens color light output
    The projector's high light output ensures that presentations are seen clearly in any classroom or meeting room. There's a choice of three brightness modes to suit any environment, from bright daylight to darkened rooms.
  • Ultra-short throw distance
    Present images up to 80" across (2.03 m diagonal) with the projector just 47 cm from the screen or whiteboard. Distracting glare and shadows are greatly reduced, as well as saving space in a classroom or meeting room.
  • WXGA resolution for detail-packed presentations
    WXGA (1280 x 800) resolution gives lots of crisp, fine detail: perfect for making presentations direct from a laptop or PC.
  • 3LCD BrightEra technology
    The projector's efficient 3LCD panel system is enhanced by advanced BrightEra technology by Sony. You'll see the difference with impressively bright, consistent, high-resolution images and increased panel reliability.
  • Gamma adjustment
    A gamma curve adjustment offers three settings for accurate tonal reproduction with rich, vibrant colors and clear, easy-to-read text.
  • Long-lasting lamp for reduced maintenance and down time
    Present for longer without interruption, with reduced maintenance that contributes directly to lower lifetime ownership costs. Filter cleaning cycles are synchronized with lamp replacement, cutting scheduled maintenance visits even further.
  • Energy-saving features
    Advanced lamp technology enables a range of energy-saving features. Auto light dimming mode saves energy when the projector is left on without being used. During projection, auto picture mode automatically adjusts light output to suit the scene being projected. Picture mute dims the projected image when it's not needed to minimize energy consumption.
  • USB display for easy one-cable PC connection
    Present pictures and audio from a connected PC or Mac with just one USB cable - you don't even need to install a software driver.
  • PC-free interactivity
    Up to two people can sketch, draw, write and annotate on-screen presentations with no need for a connected computer. Now with richer drawing functions and auto pen speed for even smoother drawing.
  • Whiteboard mode
    Instantly turn any projection surface into an interactive whiteboard. Make annotations on presentations or images from an external source such as a document camera. Save annotations as snapshots for instant recall.
  • Input label function
    It's easier to keep track of various sources with an input label function that lets you see the name of connected PCs, cameras, BD/DVD players and other devices on screen.
  • Clear, rich audio from built-in speaker
    There's no need to add an extra audio system: enjoy rich, room-filling sound from the powerful 16 W speaker.
  • Quick and easy to install
    Adjustable optical zoom and lens shift simplify speedy, fuss-free installation in any classroom. Generous connections simplify hook-ups with PCs, DVD players, microphones, and other AV devices.
  • Easy wall mounting
    Installation's even easier with a wall mounting bracket design that gives extra flexibility in rooms with low ceilings.
Sony VPL-SW636C - 3LCD projector - short-throw - LAN
3LCD projector
Brightness (White)
3300 lumens
Brightness (Colour)
1900 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Short-throw fixed lens
Bulb type
Ultra high-pressure mercury 225 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i
Speakers
Speaker(s) - integrated
341 Watt
37.2 cm x 38.2 cm x 13.8 cm
6.3 kg
3LCD projector
Ethernet
Projector
Brightness (White)
3300 lumens
Brightness (Colour)
1900 lumens
Brightness (Reduced)
1900 lumens
Contrast Ratio
3000:1
Image Size
165 cm - 279 cm
Throw Ratio
0.27:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
OSD Languages
Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, Ultra Short Throw Technology, Auto Dimming Mode, Lamp Dimming Function, USB Viewer, USB Display, Eco Mode, smartphone remote control
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.03x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-1 / +4
Lens Shift Type
Manual
Vertical Lens Shift
3.7% / 3.7%
Horizontal Lens Shift
2.3% / 2.3%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x RGB input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x microphone input
Interactive Pen, remote control
1 x USB cable - 5 m
Power Source
AC
341 Watt
Power Consumption Stand by
0.5 Watt
37.2 cm
38.2 cm
13.8 cm
6.3 kg
20 - 80% (non-condensing)
Sound Emission
28 dB
C058 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
