Sony VPL-MX20 LCD XGA Projector - 2500 ANSI Lumens
Quicklinx: 69HVWS00 Mfr#: VPL-MX20
When you've only got a short opportunity to impress your audience, you want to be in complete control. This stylish projector has been designed to be exceptionally portable. Lightweight and slim with a contemporary ergonomic design it is the ultimate personal projector for business professionals striving to create an impact with their presentations. With a depth of 45mm and weight of only 1.7 kg, it is lightweight and easy to carry. The projector's five step advanced intelligent auto set up feature means it is quick and simple to operate. In addition, the off-and-go function means it can be unplugged immediately after being switched off.
By combining an optical system that incorporates Sony's innovative BrightEra with Long Lasting Optics technology and a 3LCD projection system, the VPL-MX20 delivers high picture quality in XGA (1024 x 768) resolution and a high brightness of 2500 lumens. This allows professional presentations to be delivered in virtually any presentation environment.
  • BrightEra with Long Lasting Optics technology
    This is a more advanced version of Sony's original BrightEra technology which was developed to deliver improved panel light resistance, higher brightness, higher resolution and increased panel reliability. This technology incorporates inorganic polarizes.
  • Color light output - 2500 lumens
    Color light output is a metric that measures a projector's ability to deliver color. Color light output provides users with a simple, accurate and easy to understand way to evaluate projector color performance to make better buying decisions.
  • Ultra-portable
    Weighing in at just 1.7kg with a depth of only 45mm and magnesium ergonomic curved edge body design, it's simply the ultimate in mobility, durability and style.
  • Off and go function
    Power off, unplug and go. The fan continues to cool the VPL-MX25 after the power supply is removed, enabling users to unplug the projector immediately after use, without damaging the lamp or optics. Other projectors need to remain connected to the power supply to cool the projector after use.
  • Quick start and re-start
    8 second start up and 5 second restart.
  • Dynamic detail enhancer
    Generates high quality images through the interlace/progressive conversion processor, resulting in extremely accurate image reproduction.
  • Digital zoom (4x)
    Highlight a portion of the image displayed by 4X for audience impact.
  • Panel key lock
    Locks the keys on the control panel so the projector can only be operated by the remote control.
Sony VPL-MX20 - LCD projector - portable - black, silver
LCD projector
Black, silver
Brightness
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
650:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 200 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
Video Input
RGB, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Modes
575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
290 Watt
27.3 cm x 20.6 cm x 4.5 cm
1.7 kg
3-year warranty
LCD projector
Enclosure Colour
Black, silver
Projector
Brightness
2500 lumens
Brightness (Colour)
2500 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
650:1
Image Size
76 cm - 381 cm
Digital Zoom Factor
4x
Resolution
XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768)
Max Sync Rate (V x H)
92 Hz x 80 Hz
Bulb type
UHP 200 Watt
Bulb life cycle
BrightEra
Lens
Lens Aperture
F/1.65-1.8
Zoom Type
Powered
Zoom Factor
1.2x
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video
Video Modes
Input Device
External
1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15)
Carrying case, wireless remote control
1 x VGA cable - 2 m
Security Features
Control panel lock
FCC Class B certified, IC Class B, CSA, VCCI, C-Tick, cUL, DEMKO, CB, EMC, EK, IEC 60950-1, EN 60950-1, JEITA
290 Watt
27.3 cm
20.6 cm
4.5 cm
1.7 kg
Limited warranty - 3 years - pick-up and return , Technical support - phone consulting - 3 years
35 °C
35 - 85%
Sound Emission
38 dB
