Featuring a very wide range of lens-shift adjustment, and interchangeable lenses, this is a projector that installers can easily fit into awkward places, often reusing mounts and fixtures. The VPL-FX500L is so flexible that it can replace a very wide range of existing equipment.
Outstanding image quality is just one of the many benefits of Sony's 3 LCD-BrightEra technology. By reducing the effects of UV light, it lengthens panel life, brightens the image, and improves color rendition.
Maintenance is kept to an absolute minimum. Automatic lamp-switching means at the end of a lamp's working life, another one, already in place, is brought into use. Synchronized lamp and filter cycles halve the required number of maintenance visits. The VPL-FX500 is the perfect choice for venues that need an extremely bright projector with a high quality image and low maintenance costs
Sony's BrightEra Panel technology gives more accurate color rendition, higher brightness and longer lifespan for a lower total cost of ownership. -
Wide zoom range as standard
Standard lens has wide zoom capability for more flexibility over positioning of projector, which can installed closer to or further back from the screen. -
Wide lens shift range
Wide lens shift range means the projector can be positioned closer to the ceiling, or horizontally offset to avoid ceiling obstacles. -
Lamp/filter replacement cycles synchronized
Synchronized lamp and filter replacement effectively halves the number of visits needed to maintain the projector in peak operating condition. -
Lower power consumption
Lower operating power consumption helps reduce energy consumption and lowers running costs. -
Multiple input types
A wide range of inputs makes it easy to source presentations from almost any type of device including 1080p HD video and up to UXGA digitally from computers. -
Wide range of image adjustment
Wide range of image adjustment allows the projector to be installed in a much wider range of locations. Installers are more likely to be able to use existing mounts, or to work around existing obstructions.
- Sony VPL-FX500L - 3LCD projector - no lens - grey, white
- 3LCD projector
- Grey, white
- Brightness
- 7000 lumens
- Brightness (Colour)
- 7000 lumens
- Contrast Ratio
- 2500:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens
- No lens
- Bulb type
- High-pressure mercury 330 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
- Video Output
- RGB
- Power
- AC 120/230 V (50/60 Hz)
- 53 cm x 54.5 cm x 21.3 cm
- 20 kg
- 3LCD projector
- Enclosure Colour
- Grey, white
Projector
- Brightness
- 7000 lumens
- 7000 lumens
- Brightness (Reduced)
- 5600 lumens
- Contrast Ratio
- 2500:1
- Image Size
- 102 cm - 1524 cm
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 93 Hz x 93 kHz
- Bulb type
- Bulb life cycle
- OSD Languages
- Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Persian
- High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra
Lens
- No lens
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video, DVI
Video Output
- Analogue Video Signal
- RGB
Input Device
- External
- 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x component video / RGB input - BNC x 5 , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x remote control , 1 x DVI-D input - 24+1 pin digital DVI
- Included Accessories
- Wireless remote control
- Voltage Required
- 53 cm
- 54.5 cm
- 21.3 cm
- 20 kg
- 0 °C
- 40 °C
- 35 - 85%
