Sony VPL-FX35 XGA LCD 5000 Lumens Projector
Quicklinx: 9RMDWS00 Mfr#: VPL-FX35
Designed to fit into almost any situation that needs a high quality projector, the VPL-FX35 is perfect for installations and for updating older equipment; installers will often be able to re-use existing mounts and fittings. Versatile image adjustability and lens options allow installers to place the VPL-FX35 in locations where other projectors would struggle to work - even in high ambient light.
In addition to all this flexibility, the VPL-FX35 has excellent image capabilities and a long lifespan. Sony's BrightEra technology improves and maintains color purity throughout the life of the system by protecting the LCD panels against harmful ultra violet light.
There's no need to worry about connections, either, because the VPL-FX35 has the usual host of inputs.
Simple to use and maintain, extremely functional, and with a low cost-of-ownership, this is an obvious projector choice for venues that demand quality and practicality.
  • BrightEra technology
    Sony's BrightEra Panel technology gives more accurate color rendition, higher brightness and longer lifespan for a lower total cost of ownership.
  • Very high brightness
    Very high brightness for a clearer image in high ambient light. Suitable for larger venues.
  • Wide zoom range as standard
    Standard lens has wide zoom capability for more flexibility over positioning of projector, which can installed closer to or further back from the screen.
  • Wide lens shift range
    Wide lens shift range means the projector can be positioned closer to the ceiling, or horizontally offset to avoid ceiling obstacles.
  • Interchangeable lenses
    Chose different lenses for increased flexibility.
  • Long lamp replacement time
    Fewer visits by maintenance personnel because of longer lamp life.
  • Lamp/filter replacement cycles synchronized
    Synchronized lamp and filter replacement effectively halves the number of visits needed to maintain the projector in peak operating condition.
  • Lower power consumption
    Lower operating power consumption helps reduce energy consumption and lowers running costs.
  • Multiple input types
    A wide range of inputs makes it easy to source presentations from almost any type of device including 1080p HD video and up to UXGA digitally from computers.
  • Monitor output
    External monitor output that allows presenters to see their slides and videos on a smaller screen in their field of view, so that they never have to turn their back on the audience.
  • Wide range of image adjustment
    Wide range of image adjustment allows the projector to be installed in a much wider range of locations. Installers are more likely to be able to use existing mounts, or to work around existing obstructions.
Sony VPL-FX35 - 3LCD projector - standard lens - grey, white
3LCD projector
Grey, white
Ethernet, Fast Ethernet
Brightness
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
High-pressure mercury 275 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Digital Video Standard
Digital Visual Interface (DVI)
Video Modes
1080/60i, 480/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 750/50p, 750/60p
Video Output
RGB
39 cm x 47.7 cm x 14.8 cm
8 kg
3LCD projector
Ethernet
Enclosure Colour
Grey, white
Projector
Brightness
5000 lumens
Brightness (Colour)
5000 lumens
Brightness (Reduced)
4000 lumens
Contrast Ratio
2000:1
Image Size
102 cm - 1524 cm
Throw Ratio
1.4 - 2.3:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
Bulb life cycle
OSD Languages
Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Persian
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra
Lens
Standard lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
51% / 0%
Horizontal Lens Shift
33% / 33%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video, DVI
Video Modes
Video Output
Analogue Video Signal
RGB
Input Device
External
1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x remote control , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x DVI-D input - 24+1 pin digital DVI , 1 x component video / RGB input - BNC x 5 , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Wireless remote control
39 cm
47.7 cm
14.8 cm
8 kg
35 - 85%
9RMD C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.23
