The VPL-FW65 installation projector is ideal for a wide range of business, education and entertainment applications. The energy-efficient High Pressure Mercury (HPM) lamp source is teamed with Sony's advanced BrightEra 3LCD projection engine to deliver extremely bright, crisp WXGA resolution images with powerful 6300 lumens maximum light output and rich, stable colors. Reality creation and contrast enhancer technologies fine-tune image quality even further to assure exceptional clarity and realism with every presentation.
Offering a stylish blend-in design, tidy cable management and low fan noise, the VPL-FW65 fits smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Seamlessly blend images from multiple projectors to create super-sized displays, or project accurately proportioned images onto angled or curved surfaces. Mount the projector at any angle, even on its side or upside down. Set-up is easy with a friendly installation menu.
Very high image quality with BrightEra 3LCD projection engine
The energy-efficient High Pressure Mercury (HPM) lamp source is coupled with Sony's acclaimed BrightEra 3LCD projection engine to ensure high 6300 lumen image brightness with vivid, natural color reproduction. -
Advanced picture refinement technologies
Picture quality is boosted by advanced processing featured on Sony home cinema projectors. Reality Creation uses a powerful pattern-matching database to optimize every pixel. Contrast Enhancer actively analyzes and refines dark and light image areas for sparkling highlights and rich, deep blacks. -
Crisp WXGA image quality
View PC presentations or videos with WXGA (1280 x 800) 16:10 resolution. -
Hassle-free automatic filter cleaning
Focus on great-looking images instead of arduous maintenance tasks: automated filter cleaning system removes dust every 100 hours. -
Energy-saving lamp dimming mode
Gradually reduces lamp brightness and power consumption without compromising picture quality when the projector isn't being actively used. As soon as it’s needed, full brightness is restored instantly. -
Powered wide lens shift
Generous lens shift adjustments give more flexibility for positioning the projector where you need it: close to ceilings or even horizontally offset. -
Supports HDBaseT
Simpler, more cost-effective installation and connectivity with digital transmission of HD video, audio and networking/control over a single Ethernet cable. -
Create super-size displays with edge blending
Seamlessly join accurately colour-matched images from multiple projectors, simplifying creation of stunning super-size displays for corporate and education. -
Project onto non-flat surfaces with image warping
Easily correct image geometry for natural-looking projections – even on convex or concave surfaces. Corner and edge correction can be easily adjusted with the supplied remote and on-screen menu. -
Quiet operation
Low fan noise ensures discreet, unobtrusive operation in quiet environments from museums and galleries to lecture theatres. -
Slim, attractive blend-in design
The slim, stylish case design features a flat top surface that blends in discreetly when the projector is ceiling mounted. The clean appearance is accentuated by a terminal cover that reduces cable clutter. -
Picture mode
Picture mode ensures great-looking presentations in a wide range of operating conditions. Select standard, dynamic, brightness priority or multi screen mode for optimised image quality, with any source and in every room. -
Simple set-up with friendly installation menu
Easily adjust projector settings with remote commander, including image warping and edge blending. -
Project side by side
Project images from two inputs at the same time: ideal for applications such as video conferencing and medical training where two images need to be seen simultaneously.
- Sony VPL-FW65 - 3LCD projector - standard lens - LAN
- 3LCD projector - 720p
- Brightness (White)
- 6300 lumens
- Brightness (Colour)
- 6300 lumens
- Contrast Ratio
- 2000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Lens
- Standard lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- Ultra high-pressure mercury 370 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
- Video Modes
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Power
- AC 120/230 V (50/60 Hz)
- 455 Watt
- 46 cm x 51.5 cm x 16.9 cm
- 13 kg
- Networking
- Ethernet
Projector
- 6300 lumens
- 6300 lumens
- Brightness (Reduced)
- 4780 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 102 cm - 1524 cm
- Throw Ratio
- 1.39 - 2.23:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Display Format
- 3,072,000 pixels (1280 x 800) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
- Edge blending, High-bandwidth Digital Content Protection System (HDCP), Side-by-Side, 3LCD Technology, BrightEra, Reality Creation, Image Warping, Lamp Dimming Function, Contrast Enhancer
Lens
- Standard lens
- Focus Type
- Powered
- Zoom Type
- Powered
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Powered
- Vertical Lens Shift
- 5% / 60%
- Horizontal Lens Shift
- 32% / 32%
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, DVI
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
- DVI-D with HDCP Input
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D input - 24+1 pin digital DVI , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45 , 1 x composite video input - BNC , 1 x VGA output - 15 pin D-Sub (DB-15) , 2 x audio line-out - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x remote control - mini-phone stereo 3.5 mm (management)
- Included Accessories
- Remote control
- Power Source
- AC
- Nominal Voltage
- 455 Watt
- Power Consumption Stand by
- 0.5 Watt
- 46 cm
- 51.5 cm
- 16.9 cm
- 13 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 28 dB
C2G 1m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £7.55 |
C2G 2m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £8.83 |
C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter | In Stock | £5.00 |
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £8.34 |
