Sony VPL-EX345 XGA 4200lm RGB HDMI 3LCD Projector
Quicklinx: C053WS00 Mfr#: VPL-EX345
The VPL-EX345 outputs powerful 4,200 lumens Color Light Output yet is designed to deliver a low total cost of ownership with its economical portable design and up to 10,000 hours expected lamp life. It incorporates XGA (1024 x 768) BrightEra LCD imagers. The powerful A/V features include a 1.6x flexible standard zoom lens and a variety of inputs that allow the projector to fit a broad range of applications.
  • Impressive audio output
    With an integrated speaker system delivering 16 watts of power, this projector ensures clear, powerful sound for any presentation or multimedia content.
  • Versatile connectivity
    Equipped with a variety of interfaces including HDMI, S-Video, and component video, this projector offers flexible connection options to suit a wide range of devices.
  • Bright and clear visuals
    Featuring 4200 lumens of brightness and a native XGA resolution of 1024 x 768, the projector produces vivid, sharp images for an exceptional viewing experience.
  • Long-lasting lamp life
    The projector's lamp offers a life cycle of up to 4000 hours in normal mode and 10000 hours in economic mode, providing reliable long-term use without the frequent need for replacements.
  • Enhanced image quality
    Thanks to 3LCD Technology and BrightEra, the projector delivers improved color light output and higher efficiency, resulting in brighter images and more vibrant colors.
Sony VPL-EX345 - 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness (White)
4200 lumens
Brightness (Colour)
4200 lumens
Contrast Ratio
3300:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Ultra high-pressure mercury 225 watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
324 watt
36.5 cm x 25.2 cm x 9.62 cm
4 kg
Pricing Type
Refurbished - Grade A
1-year warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness (White)
4200 lumens
Brightness (Colour)
4200 lumens
Brightness (Reduced)
2500 lumens
Contrast Ratio
3300:1
Image Size
76.2 cm - 762 cm
Throw Ratio
1.4 - 2.27:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, Auto Dimming Mode, USB Viewer
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, component video, composite video, S-Video, RGB
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
Remote control
Pricing Type
Power Source
AC
324 watt
Power Consumption Stand by
0.5 watt
36.5 cm
25.2 cm
9.62 cm
4 kg
Limited warranty - 1 year
20 - 80% (non-condensing)
29 dB
C053 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
