Combining superb XGA image quality with smart energy-efficient features, the VPL-EX255 portable projector enhances learning with powerful presentations that really stand out. Simple to use and wireless ready, the projector is ideal for maximizing student engagement in today's networked classrooms, making it your ideal partner throughout the busy school day.
Sony BrightEra panel technology assures clear pictures in any conditions, from daylight to darkened classrooms. Plenty of interfaces allow easy connection, while a choice of Picture Modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. Adding an optional Wi-Fi module lets students and teachers wirelessly share homework, images and graphics from mobile devices like smartphones and tablets. There's a wide range of smart energy-saving features built in.
Energy efficient with long-lasting lamp
The lamp driver optimally controls the wattage of the lamp and achieves a long-lasting lamp. The recommended lamp replacement time is extended by 43%, compared to the previous model. -
Advanced energy-saving features
Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto light dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto lamp mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption. -
High image quality 3LCD BrightEra natural and vivid color images
XGA (1024 x 768) 4:3 screen resolution, 3LCD BrightEra natural and vivid color images, plus various Picture Modes for optimizing image quality, make the projector one of the best in its class. Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, ensuring colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms. -
Various picture modes for optimal picture quality
The projector has six available picture modes for correct picture quality: Dynamic, Standard, Presentation, Blackboard, Game, and Cinema. With six picture modes and three brightness modes combined, the user can select the most suitable picture/brightness combination according to the picture source and environment, to create the optimal image. -
Network presentation (LAN/Wireless LAN)
When the projector is installed in a LAN, presentations can be projected from any PC and Mac on the network. A tablet or smartphone can be connected at the same time. You can project jpg, pdf and other supported formats. Up to four users can project PC/Mac images simultaneously, while up to eight users can connect to one projector. -
USB display
The projector allows you to display pictures and audio with one USB cable. You do not need to install any driver for this function. It is a convenient way to connect to the projector when you want to connect easily. -
Input label
The input label, which appears in the input menu on screen, can be customized. This gives users a clear understanding of which equipment is connected. -
Built-in speaker
The projector includes a 16W monaural speaker.
- Sony VPL-EX255 - 3LCD projector
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 3300 lumens
- Contrast Ratio
- 3300:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- Ultra high-pressure mercury 210 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
- Video Modes
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 301 Watt
- 36.5 cm x 25.2 cm x 9.62 cm
- 4 kg
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 3300 lumens
- Brightness (Reduced)
- 1700 lumens
- Contrast Ratio
- 3300:1
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 1.4 - 2.27:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 93 Hz x 93 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- 3LCD Technology, BrightEra, Automatic Brightness Adjustment, Auto Lamp Dimming Function
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2
- Power Source
- AC
- Voltage Required
- 301 Watt
- Power Consumption Stand by
- 0.5 Watt
- 36.5 cm
- 25.2 cm
- 9.62 cm
- 4 kg
- 0 °C
- 40 °C
- 35 - 85% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
