The VPL-EX130 data projector is a compact, bright, affordable and Eco-friendly - is an excellent choice for both education and business.
- Sony VPL-EX130 - LCD projector
- LCD projector
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 700:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
- Video Output
- RGB, component video
- Environmental Standards
- ENERGY STAR Qualified
- Power
- AC 120/230 V (50/60 Hz)
- 270 Watt
- 31.3 cm x 26.9 cm x 11.4 cm
- LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 lumens
- Brightness (Reduced)
- 2000 lumens
- Contrast Ratio
- 700:1
- Image Size
- 102 cm - 762 cm
- Projection Distance
- 1.2 m - 10.3 m
- Resolution
- XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
- 4:3
- Display Format
- 786,432 pixels (1,024 x 768) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
- BrightEra
Lens
- Lens Aperture
- F/1.65-1.8
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
Video Output
- Analogue Video Signal
Input Device
- External
- 1 x S-video input - 4 pin mini-DIN , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
- Included Accessories
- Wireless remote control
- ENERGY STAR
- Voltage Required
- 270 Watt
- 31.3 cm
- 26.9 cm
- 11.4 cm
- 0 °C
- 40 °C
- 35 - 85%
- Sound Emission
- 39 dB
- Sound Emission (Economic Mode)
- 31 dB
