Sony VPL-EX130 XGA Projector
Quicklinx: 6LK2WS00 Mfr#: VPL-EX130
The VPL-EX130 data projector is a compact, bright, affordable and Eco-friendly - is an excellent choice for both education and business.
Sony VPL-EX130 - LCD projector
LCD projector
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
700:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 210 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Output
RGB, component video
Environmental Standards
ENERGY STAR Qualified
270 Watt
31.3 cm x 26.9 cm x 11.4 cm
LCD projector
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
700:1
Image Size
102 cm - 762 cm
Projection Distance
1.2 m - 10.3 m
Resolution
XGA - XGA (1024 x 768) (native) / 1400 x 1050 (resized)
Native Aspect Ratio
4:3
Display Format
786,432 pixels (1,024 x 768) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
UHP 210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
BrightEra
Lens
Lens Aperture
F/1.65-1.8
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Output
Analogue Video Signal
Input Device
External
1 x S-video input - 4 pin mini-DIN , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
Wireless remote control
ENERGY STAR
270 Watt
31.3 cm
26.9 cm
11.4 cm
35 - 85%
Sound Emission
39 dB
31 dB
