Sony VPL EX100 XGA LCD Projector - 2300 ANSI Lumens
Quicklinx: 77M2WS00 Mfr#: VPL-EX100
Sony's VPL-E Series Data Projectors are designed to deliver a low total cost of ownership, and include eco-friendly features, thanks to a long-lasting lamp design and low power consumption. These projectors are not only stylish but also offer native XGA resolution for high image quality with a high brightness of 2700 lumens. Delivering superb images and simple operation, Sony's VPL-E Series Projectors provide an excellent balance between quality and cost, ideal for use in education or business.
  • Long-lasting lamp
    By incorporating a high-performance lamp and advanced lamp-control technology, VPL-E series projectors deliver an extremely long lamp replacement time.
  • Lamp and filter synchronized maintenance
    When it's time to clean the air filter, a reminder message is clearly displayed on screen. Like the lamp, the air filter has an approximate 6,000-hour cleaning cycle. Users can therefore replace both the lamp and the filter at the same time, saving maintenance effort and cost.
  • Low power consumption
    The VPL-E series offers remarkably low power consumption, allowing users to make significant savings on their electricity expenses.
  • Simple projector replacement
    The standard 1.3x zoom lens enables installation flexibility when replacing an existing projector with the VPL-E series. There's no need to change ceiling mount positions.
  • High picture quality and bright images
    By combining inorganic LCD panels that utilize Sony's BrightEra technology with a 3LCD projection system, the VPL-E series offers high picture quality and brightness.
  • 3LCD projection offers brilliant color performance
    The VPL-E series adopts a 3LCD projection system incorporating three LCD panels. This system enables each projector to present bright and natural images.
  • 12-bit 3D gamma correction
    The VPL-E series incorporates 12-bit 3D gamma correction circuitry to perform highly accurate gamma correction, achieving smoother gradations and a richer gray scale.
  • I/P conversion and film mode
    The video signal processing technology that Sony has incorporated in the VPL-E series offers I/P conversion and 2-3 pull-down to generate high-quality images with outstanding clarity.
  • Image freeze
    The image freeze function can display a freeze frame to allow the presenter to prepare or switch to the next image.
  • Off and go
    Once a presentation is complete, a VPL-E series projector can be immediately moved to the next location, simply by turning it off and unplugging the AC power cord - there's no need to wait for the fan to stop.
  • Front exhaust
    Users can run an optimum presentation even in a quiet environment, and participants seated to the side of the projector are not bothered by hot air and noise.
Sony VPL-EX100 - 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness
2300 lumens
Brightness (Colour)
2300 lumens
Contrast Ratio
2200:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 210 Watt
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Modes
575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
Video Output
RGB
Speakers
Speaker(s) - integrated
285 Watt
37.2 cm x 29.8 cm x 9 cm
4.1 kg
3LCD projector
Built-in Devices
Speaker
Projector
Brightness
2300 lumens
Brightness (Colour)
2300 lumens
Contrast Ratio
2200:1
Image Size
76.2 cm - 762 cm
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Display Format
786,432 pixels (1,024 x 768) x 3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
UHP 210 Watt
Controls & Adjustments
Keystone correction
Integrated de-interlacer (progressive scan), 3LCD Technology
Lens
Lens Aperture
F/1.75-2.17
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x S-video input - 4 pin mini-DIN , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
Lens cover, wireless remote control
1 x VGA cable - 2 m
Security Features
Password protection, control panel lock, security bar, security label
285 Watt
Power Consumption Operational (Standby)
0.5 Watt
Software Included
Drivers & Utilities
37.2 cm
29.8 cm
9 cm
4.1 kg
35 °C
35 - 85%
