Sony's VPL-E Series Data Projectors are designed to deliver a low total cost of ownership, and include eco-friendly features, thanks to a long-lasting lamp design and low power consumption. These projectors are not only stylish but also offer native XGA resolution for high image quality with a high brightness of 2700 lumens. Delivering superb images and simple operation, Sony's VPL-E Series Projectors provide an excellent balance between quality and cost, ideal for use in education or business.
Long-lasting lamp
By incorporating a high-performance lamp and advanced lamp-control technology, VPL-E series projectors deliver an extremely long lamp replacement time. -
Lamp and filter synchronized maintenance
When it's time to clean the air filter, a reminder message is clearly displayed on screen. Like the lamp, the air filter has an approximate 6,000-hour cleaning cycle. Users can therefore replace both the lamp and the filter at the same time, saving maintenance effort and cost. -
Low power consumption
The VPL-E series offers remarkably low power consumption, allowing users to make significant savings on their electricity expenses. -
Simple projector replacement
The standard 1.3x zoom lens enables installation flexibility when replacing an existing projector with the VPL-E series. There's no need to change ceiling mount positions. -
High picture quality and bright images
By combining inorganic LCD panels that utilize Sony's BrightEra technology with a 3LCD projection system, the VPL-E series offers high picture quality and brightness. -
3LCD projection offers brilliant color performance
The VPL-E series adopts a 3LCD projection system incorporating three LCD panels. This system enables each projector to present bright and natural images. -
12-bit 3D gamma correction
The VPL-E series incorporates 12-bit 3D gamma correction circuitry to perform highly accurate gamma correction, achieving smoother gradations and a richer gray scale. -
I/P conversion and film mode
The video signal processing technology that Sony has incorporated in the VPL-E series offers I/P conversion and 2-3 pull-down to generate high-quality images with outstanding clarity. -
Image freeze
The image freeze function can display a freeze frame to allow the presenter to prepare or switch to the next image. -
Off and go
Once a presentation is complete, a VPL-E series projector can be immediately moved to the next location, simply by turning it off and unplugging the AC power cord - there's no need to wait for the fan to stop. -
Front exhaust
Users can run an optimum presentation even in a quiet environment, and participants seated to the side of the projector are not bothered by hot air and noise.
- Sony VPL-EX100 - 3LCD projector
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 2300 lumens
- Brightness (Colour)
- 2300 lumens
- Contrast Ratio
- 2200:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- UHP 210 Watt
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
- Video Modes
- 575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 285 Watt
- 37.2 cm x 29.8 cm x 9 cm
- 4.1 kg
- 3LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 2300 lumens
- 2300 lumens
- Contrast Ratio
- 2200:1
- Image Size
- 76.2 cm - 762 cm
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Display Format
- 786,432 pixels (1,024 x 768) x 3
- Max Sync Rate (V x H)
- 93 Hz x 93 kHz
- Bulb type
- UHP 210 Watt
- Controls & Adjustments
- Keystone correction
- Integrated de-interlacer (progressive scan), 3LCD Technology
Lens
- Lens Aperture
- F/1.75-2.17
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x S-video input - 4 pin mini-DIN , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable - 2 m
- Security Features
- Password protection, control panel lock, security bar, security label
- Voltage Required
- 285 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- Software Included
- Drivers & Utilities
- 37.2 cm
- 29.8 cm
- 9 cm
- 4.1 kg
- 0 °C
- 35 °C
- 35 - 85%
