Sony VPL-EW345 XGA 4200lm RGB HDMI 3LCD Projector
Quicklinx: C04TWS00 Mfr#: VPL-EW345
The VPL-EW345 outputs powerful 4,200 lumens Color Light Output yet designed to deliver a low total cost of ownership with its economical portable design and up to 10,000 hours expected lamp life. It incorporates WXGA (1280x800) BrightEra LCD imagers. The powerful A/V features include a 1.6x flexible standard zoom lens and a variety of inputs that allow the projector to fit a broad range of applications. The versatile inputs include 2x HDMI.
  • Robust audio output
    With an integrated speaker system delivering 16 W of power, this projector ensures clear, powerful sound for any presentation or multimedia content.
  • Versatile connectivity
    Equipped with a wide range of interfaces including HDMI, VGA, USB, and Ethernet, this projector offers flexible connection options for a variety of devices.
  • Bright and clear visuals
    Featuring 4200 lumens of brightness and a WXGA resolution, the projector delivers vivid, sharp images even in well-lit environments.
  • Long-lasting performance
    The projector lamp offers a life cycle of up to 4000 hours in normal mode and up to 10000 hours in economic mode, ensuring reliable performance over time.
  • Enhanced image quality
    3LCD Technology and BrightEra ensure outstanding color accuracy and image clarity, making it ideal for high-quality presentations and multimedia.
Sony VPL-EW345 - 3LCD projector
3LCD projector - 720p
Built-in Devices
Speaker
Brightness
4200 lumens
Brightness (Colour)
4200 lumens
Contrast Ratio
3700:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Ultra high-pressure mercury 225 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
322 Watt
36.5 cm x 25.2 cm x 96.2 cm
4.1 kg
1-year warranty
Built-in Devices
Speaker
Ethernet
Projector
Brightness
4200 lumens
Brightness (Colour)
4200 lumens
Contrast Ratio
3700:1
Image Size
76 cm - 762 cm
Throw Ratio
1.1 - 1.79:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
3LCD Technology, BrightEra, USB Viewer, Eco Mode, Remote control application support
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
Wireless remote control
Power Source
AC
322 Watt
Power Consumption Stand by
0.5 Watt
36.5 cm
25.2 cm
96.2 cm
4.1 kg
Limited warranty - 1 year
20 - 80% (non-condensing)
29 dB
C04T C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
