The VPL-EW345 outputs powerful 4,200 lumens Color Light Output yet designed to deliver a low total cost of ownership with its economical portable design and up to 10,000 hours expected lamp life. It incorporates WXGA (1280x800) BrightEra LCD imagers. The powerful A/V features include a 1.6x flexible standard zoom lens and a variety of inputs that allow the projector to fit a broad range of applications. The versatile inputs include 2x HDMI.
Robust audio output
With an integrated speaker system delivering 16 W of power, this projector ensures clear, powerful sound for any presentation or multimedia content. -
Versatile connectivity
Equipped with a wide range of interfaces including HDMI, VGA, USB, and Ethernet, this projector offers flexible connection options for a variety of devices. -
Bright and clear visuals
Featuring 4200 lumens of brightness and a WXGA resolution, the projector delivers vivid, sharp images even in well-lit environments. -
Long-lasting performance
The projector lamp offers a life cycle of up to 4000 hours in normal mode and up to 10000 hours in economic mode, ensuring reliable performance over time. -
Enhanced image quality
3LCD Technology and BrightEra ensure outstanding color accuracy and image clarity, making it ideal for high-quality presentations and multimedia.
- Sony VPL-EW345 - 3LCD projector
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 4200 lumens
- Brightness (Colour)
- 4200 lumens
- Contrast Ratio
- 3700:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- Ultra high-pressure mercury 225 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
- Video Modes
- 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 322 Watt
- 36.5 cm x 25.2 cm x 96.2 cm
- 4.1 kg
- 1-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 4200 lumens
- 4200 lumens
- Contrast Ratio
- 3700:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.1 - 1.79:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Display Format
- 3,072,000 pixels (1280 x 800) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
- 3LCD Technology, BrightEra, USB Viewer, Eco Mode, Remote control application support
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Power Source
- AC
- Voltage Required
- 322 Watt
- Power Consumption Stand by
- 0.5 Watt
- 36.5 cm
- 25.2 cm
- 96.2 cm
- 4.1 kg
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission (Economic Mode)
- 29 dB
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
