This projector is ideal for mid-sized or larger classrooms and meeting rooms. Quiet, compact and powerful, it delivers bright, detail-packed WXGA images with impressive output that can be seen clearly even in bright rooms, with its 3LCD technology assuring natural, vivid colors. It is an ideal partner for the integrated AV / IT environments, expanding your connectivity options with dual HDMI ports and direct USB display connection. A convenient input labeling makes life simpler, confirming on screen the name of connected devices. Add this projector to a network and see presentations from up to four connected computers simultaneously. Control the projector remotely from smartphones and tablets. You don't even need to bring a PC to meetings - just slip in a USB thumb drive and start presenting. A range of energy-saving features and long-lasting lamp life contribute to low ownership costs. Maintenance is simplified by a rear lamp access feature.
Bright, clear images
With an impressive light output, the projector delivers crisp, bright presentations that can be seen clearly in larger classrooms or meeting rooms. The three brightness modes will suit any environment, from bright daylight to darkened rooms. -
3LCD BrightEra technology
The efficient 3LCD panel system is enhanced by advanced BrightEra technology for impressively bright, consistent, high resolution images with excellent color accuracy and impressive reliability. -
WXGA resolution
WXGA display resolution gives plenty of crisp detail, which makes it ideal for making presentations directly from a laptop, mobile device or DVD player. -
Powerful audio
The powerful built-in speaker lets your audiences hear video soundtracks with no need for additional amplification. -
Energy efficient with long-lasting lamp life
High-performance lamp technology offers reduced ownership costs plus reduced maintenance, with a long-lasting lamp. -
Advanced energy-saving
Advanced lamp technology enables a range of energy-saving features. Auto Light Dimming mode saves energy when the projector is left on without being used. Auto Picture mode automatically adjusts light output to suit the projected scene. Touching a button on the remote mutes the picture temporarily, dramatically reducing power consumption. -
Networked presentations
Project presentations from a networked PC. Present JPEG, PDF and other files wirelessly from a tablet or smartphone. -
Present wirelessly
Make presentations wirelessly from a portable or handheld device. -
USB media viewer
Slip in a USB drive and display photos, images and graphics with no PC needed. -
Dual HDMI inputs
Two HDMI input terminals make it easy to connect HDMI-equipped devices like PCs and media streaming devices. -
Easier maintenance
Lamp access has been shifted to the rear of the projector body, making lamp swaps simpler when the projector is hanging from a ceiling mount. -
Quiet operation
Low fan noise ensures discreet, unobtrusive operation in classrooms and meeting rooms.
- Sony VPL-EW315 - 3LCD projector - 802.11 b/g/n wireless / LAN
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 3800 lumens
- Brightness (Colour)
- 3800 lumens
- Contrast Ratio
- 3700:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- Ultra high-pressure mercury 225 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), IEEE 802.11 b/g/n wireless / LAN
- Video Modes
- 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 300 Watt
- 36.5 cm x 25.2 cm x 96.2 cm
- 4.1 kg
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 3800 lumens
- 3800 lumens
- Brightness (Reduced)
- 2500 lumens
- Contrast Ratio
- 3700:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.1 - 1.79:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Display Format
- 3,072,000 pixels (1280 x 800) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- OSD Languages
- Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
- 3LCD Technology, BrightEra, USB Viewer, Remote control application support
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN, Wi-Fi
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x RGB - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control, wireless LAN unit
- Voltage Required
- 300 Watt
- Power Consumption Stand by
- 0.5 Watt
- 36.5 cm
- 25.2 cm
- 96.2 cm
- 4.1 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission (Economic Mode)
- 29 dB
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
