Sony VPL-DX11 XGA Projector
Quicklinx: 5K7YWS00 Mfr#: VPL-DX11
The VPL-DX11 is a compact and portable projector which is simple to operate. This projector weighs light and has a footprint smaller than an A4 sheet of paper. This means it can be easily and quickly carried between meetings, and is ideal for small- to medium-sized rooms including corporate conference rooms and school classrooms.
By combining an optical system that incorporates Sony's innovative BrightEra technology and a 3LCD projection system, the VPL-DX11 delivers high picture quality in XGA resolution and a high brightness of 3000 lumens. This allows professional presentations to be delivered in virtually any setting and under any lighting conditions.
Features include an easy-to-use control panel with all essential controls arranged together on the top of the unit, 'Off and Go' so there is no need to wait for fans to turn off before unplugging from mains power, and 'Quick Re-start' so that it is ready to present again within 5 seconds of an accidental power-down.
  • 3LCD panel system
    3LCD is a projection system using three LCD panels (also known as high-temperature poly-silicon or HTPS). Images projected with 3LCD are bright, natural, and gentle on the eyes.
  • Brightness and high contrast
    The VPL-DX11 has a high brightness of 3000 lm. It adopts a 0.63-inch panel. The developed 200W ultra high pressure lamp has higher efficiency than current models.
  • Compact, lightweight, portable
    It is very portable with a small footprint suitable for desktop usage. "Off and Go" feature allows for quick packup after use.
  • User-friendly features and functions
    Control buttons are neatly arranged in one line. Lens shutter with picture muting allows you to pause your presentation quickly.
  • Direct power on/off
    With this function, standby mode can be skipped over to activate the projector immediately.
  • Flexible orientation
    Projector can be tilted 90 degrees upwards or downwards. This flexibility greatly expands application possibilities.
  • Password authentication system
    Once a user sets a password, the projector cannot be used without it. This function prevents unauthorized use of the projector.
  • Control panel key lock
    The control panels on the top panel of the projector can be locked, preventing inadvertent or unauthorized adjustment of the controls.
  • Smart auto pixel alignment
    This function automatically adjusts the size and phase of images and displays for optimum picture performance allowing users to concentrate on their presentations, rather than time-consuming technical adjustments.
  • Auto input search
    The VPL-DX11 automatically checks the projector's input connectors and selects the one to which an input signal is supplied. Images are projected from the moment the power is turned on.
  • Picture and audio muting
    The VPL-DX11 can mute the picture and audio temporarily from the remote commander.
  • Digital zoom
    With the 4-times digital zoom function, one section of a presentation can be zoomed in for a closer look and to convey a message more clearly.
Sony VPL-DX11 - LCD projector - portable
LCD projector
Built-in Devices
Speaker
Brightness
3000 lumens
Brightness (Colour)
3000 lumens
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHP 200 Watt
Bulb life cycle
Up to 2400 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Modes
575/50i, 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i
Speakers
Speaker(s) - integrated
320 Watt
29.5 cm x 20.4 cm x 7.4 cm
2.1 kg
LCD projector
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
2400 lumens
Image Size
102 cm - 762 cm
Digital Zoom Factor
4x
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768)
Max Sync Rate (V x H)
92 Hz x 80 kHz
Bulb type
UHP 200 Watt
Bulb life cycle
Freeze frame, Picture Muting, BrightEra
Lens
Lens Aperture
F/1.65-1.8
Zoom Type
Powered
Zoom Factor
1.2x
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm
Carrying case, wireless remote control
1 x VGA cable - 2 m
Security Features
Security lock slot (cable lock sold separately), password protection, control panel lock, security label
320 Watt
Power Consumption Operational (Standby)
3 Watt
29.5 cm
20.4 cm
7.4 cm
2.1 kg
35 °C
35 - 85%
Resources
The following resources are available for the Sony VPL-DX11 XGA Projector
