Sony VAIO E-Series  SVE1713Z1EB Core i7-3632QM 8GB 1TB Blu-ray Writer 17.3" Widescreen Windows 8
Quicklinx: 8KC6WS00 Mfr#: SVE1713Z1EB.CEK
  • Core i7
  • Windows 8
  • Bluetooth 4.0
  • IEEE 802.11n
  • BD-RE
the most popular VAIO
An easy-to-use big screen notebook for all
  • See more, do more on a large Full HD screen
  • Sleep for days, resume in seconds with Rapid Wake + Eco
  • Go easy with Backlit Keyboard and large Touchpad
  • Wrapped in style
    Anything but average, VAIO E Series laptops offer power, portability and first class features perfect for work and play. This 17.3" model features a stylish wrap design, full-size keyboard.
  • Loud and clear
    Who says you need a full home theater system to enjoy amazing audio? Built-in stereo speakers feature Clear Phase technology for crisp audio you can hear throughout the room. Whether watching a movie or video chatting with a friend, xLOUD volume-boosting technology ensures big, booming sound without sacrificing an ounce of quality.
  • The VAIO advantage
    Do faster than ever thanks to the powerful features built into your E Series laptop. Like a clickable multi-gesture touchpad for quick and convenient control, and a USB sleep charge port for charging your phone. With Rapid Wake technology, you'll never need to power down. Close the lid to enter into energy-saving sleep mode - lift the lid and resume in about two seconds.
  • Abracadabra control
    It's not wizardry, but it certainly seems like it. Just wave your hand in front of your PC's built-in webcam, and like magic, VAIO Gesture Control puts you in command of a variety of features. Skip a song and adjust the volume, navigate webpages, pause or play a DVD, deliver a PowerPoint presentation and more - without even touching your computer. It's fast, fun and incredibly convenient.
  • Night shift
    Sometimes inspiration strikes at unlikely hours. Be prepared for low-light scenarios with a backlit keyboard that makes for faster, more accurate late-night typing. LED illumination shines through the characters and between the comfortable, precision-engineered keys, framing them with a pleasant glow that helps minimize typos.
  • You decide
    The E Series is more than divine design and eye-candy color. It packs a powerful performance punch with powerful processor to suit your needs.
  • Wondrous webcam
    The built-in HD web camera features a Sony Exmor R image sensor which helps guarantee a crisp, bright picture - even in dimly-lit rooms. The webcam is perfect for snapping self-portraits, video conferencing with a client or catching up with your friends. And like magic, you can use the camera and a few simple hand gestures to skip a song, adjust the volume, navigate webpages and more without even touching your computer thanks to VAIO Gesture Control.
Sony VAIO E Series SVE1713Z1E - 17.3" - Intel Core i7 3632QM - 8 GB RAM - 1 TB HDD
Notebook
Operating System
Win 8
Intel Core i7 (3rd Gen) 3632QM / 2.2 GHz (3.2 GHz) / 6 MB Cache
8 GB DDR3 (2 x 4 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
Blu-ray Writer
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon HD 7650M
Video Memory
2 GB
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
Up to 3.5 hours
40.87 cm x 27.8 cm x 3.78 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 1 year
Notebook
Operating System
Windows 8
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Chipset
Mobile Intel HM76 Express
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Storage
Main Storage
1 TB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
BD-RE fixed
Read Speed
24x (CD) / 8x (DVD) / 6x (BD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) / 6x (BD-R) / 6x (BD-R DL)
CD / DVD Rewrite Speed
10x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) / 2x (BD-RE) / 2x (BD-RE DL)
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-reflective, VAIO Display Plus
Audio & Video
Graphics Processor
AMD Radeon HD 7650M
Video Memory
2 GB
Camera
Resolution
1.31 Megapixel
Video Resolutions
1280 x 1024
Camera Features
Exmor Technology
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Touchpad with gesture support
Communications
Wireless
Network Interface
Gigabit Ethernet
Lithium Ion
Run Time
Up to 3.5 hours
Connections & Expansion
3 x USB 2.0 , USB 3.0 , Headphone output , Microphone input , HDMI , VGA , LAN
Memory Card Reader
Yes (SD Card, Memory Stick PRO, Memory Stick Duo, SDHC Card, SDXC Card)
Software
Software Included
VAIO Update, McAfee Internet Security Suite (30 days subscription), Microsoft Office (Trial), VAIO Care, VAIO Gate, VAIO Transfer Support, Adobe Reader 10, Sony PlayMemories Home, Imagination Studio VAIO Edition, Microsoft Internet Explorer 10, VAIO Message Center, McAfee Parental Controls, VAIO Movie Creator, Album by Sony, Music by Sony
Security lock slot (cable lock sold separately), charging via USB, anti-shock hard drive, Rapid Wake + ECO Technology, ASSIST button
3.2 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
