Sony VAIO - P-Series Extended Battery
Quicklinx: 5GC7WS00 Mfr#: VGPBPL15/B.CE7
Stay productive longer while you're away from a power source with your VAIO P Series Lifestyle PC and this extended battery.
Ideal for extended computer usage around your home, office or while on the road, the VGP-BPL15/B large capacity battery is the ideal companion to your VAIO P Series Lifestyle PC. In addition to the being the perfect solution for the daily commute, lengthy meetings and long flights, a spare battery lets you use your Lifestyle PC longer when you aren't close to a power source.
Sony VGP-BPL15/B - laptop battery - Li-Ion - 4200 mAh
Laptop battery
300 g
Large capacity - Lithium Ion - 4200 mAh
Run Time (Up To)
5 hours
20 cm x 5.2 cm x 2.3 cm
VAIO P Series VGN-P11, VGN-P13, VGN-P15, VGN-P19, VGN-P21, VGN-P23, VGN-P25, VGN-P29, VGN-P31, VGN-P39, VGN-P510, VGN-P530, VGN-P588, VGNP598, VGN-P598, VGN-P610, VGN-P630, VGN-P688, VGN-P698, VGN-P699, VGN-P70, VGN-P720, VGNP788, VGN-P788, VGN-P798, VGN-P799, VGN-P80, VGN-P90; VAIO type P VGN-P70
Laptop battery
Large capacity
Lithium Ion
Voltage Provided
7.4 V
4200 mAh
Run Time (Up To)
5 hrs
20 cm
5.2 cm
2.3 cm
300 g
Sony VAIO P Series VGN-P11Z/G, VGN-P11Z/Q, VGN-P11Z/R, VGN-P11Z/W, VGN-P13GHQ, VGN-P13GHW, VGN-P13TH/Q, VGN-P13TH/W, VGN-P15GQ, VGN-P15GR, VGN-P15T/G, VGN-P15T/Q, VGN-P15T/R, VGN-P15T/W, VGN-P19VN/Q, VGN-P19WN/Q, VGN-P21S/W, VGN-P21Z/G, VGN-P21Z/Q, VGN-P21Z/R, VGN-P21Z/W, VGN-P23GQ, VGN-P25GN, VGN-P29VN/Q, VGN-P31ZK/B, VGN-P31ZK/G, VGN-P31ZK/N, VGN-P31ZK/Q, VGN-P31ZK/R, VGN-P31ZK/W, VGN-P31ZKG, VGN-P31ZKN, VGN-P31ZKQ, VGN-P31ZKW, VGN-P39VL/Q, VGN-P510T/G, VGN-P510T/Q, VGN-P510T/R, VGN-P510T/W, VGN-P530CHG, VGN-P530CHQ, VGN-P530CHR, VGN-P530CHW, VGN-P530H/G, VGN-P530H/Q, VGN-P530H/R, VGN-P530H/W, VGN-P530N/Q, VGN-P588E/Q, VGN-P588E/R, VGN-P588H/R, VGNP598E/G, VGN-P598E/Q, VGNP598E/R, VGNP598E/W, VGN-P610, VGN-P610/G, VGN-P610/Q, VGN-P610/R, VGN-P610T, VGN-P630A/Q, VGN-P688E/G, VGN-P688E/N, VGN-P688E/Q, VGN-P688E/R, VGN-P688E/W, VGN-P698E/Q, VGN-P698E/R, VGN-P699E/R, VGN-P70H/G, VGN-P70H/R, VGN-P70H/W, VGN-P720K/G, VGN-P720K/N, VGN-P720K/Q, VGN-P720K/R, VGN-P720K/W, VGN-P788K/G, VGN-P788K/N, VGNP788K/P, VGN-P788K/Q, VGN-P788K/R, VGN-P788K/W, VGN-P798K/Q, VGN-P798K/R, VGN-P799L/R, VGN-P80H/W, VGN-P90HS, VGN-P90NS, VGN-P90S , Sony VAIO type P VGN-P70H
