Designed exclusively for use with the VAIO SR Series notebooks, the VGP-PRSR1 port replicator is perfect for the constant traveler or mobile professional. Featuring a VGA port, three USB ports, Ethernet port and DC in, you can easily connect all of your peripherals such as a monitor, mouse, keyboard, printer, network cable and power supply.With a port replicator, you can quickly and easily expand to your monitor and other peripherals, without the need to plug and unplug cables each time you connect.
- Sony VAIO VGP-PRSR1 - docking station
- Product Type
- Docking station
- 33.4 cm x 13.9 cm x 3.8 cm
- 1.3 kg
- 1-year warranty
- Designed For
- VAIO PCG-SR11; VAIO SR Series VGN-SR11, VGN-SR129, VGN-SR130, VGN-SR140, VGN-SR165, VGN-SR19, VGN-SR190, VGN-SR290
- Product Type
- Docking station
- 33.4 cm
- 13.9 cm
- 3.8 cm
- 1.3 kg
- 3 x USB 2.0 - 4 pin USB Type A , 1 x network - 10Base-T/100Base-TX - RJ-45 , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x display / video - DVI-Digital - 24+1 pin digital DVI
- Limited warranty - 1 year
- Designed For
- Sony VAIO PCG-SR11K , Sony VAIO SR Series VGN-SR11M, VGN-SR129E/B, VGN-SR130E/B, VGN-SR130E/P, VGN-SR130E/S, VGN-SR130N/B, VGN-SR140DB, VGN-SR140E/B, VGN-SR165E/B, VGN-SR165E/P, VGN-SR165E/S, VGN-SR165N/B, VGN-SR190, VGN-SR190EAJ, VGN-SR190EAQ, VGN-SR190EBJ, VGN-SR190EBQ, VGN-SR190ECJ, VGN-SR190ECQ, VGN-SR190EDJ, VGN-SR190EDQ, VGN-SR190EEJ, VGN-SR190EEJ/C, VGN-SR190NAB, VGN-SR190NBB, VGN-SR190NDB, VGN-SR190NEB, VGN-SR190NGB, VGN-SR190PAB, VGN-SR190PCB, VGN-SR190PFB, VGN-SR19VN, VGN-SR19XN, VGN-SR290JTB, VGN-SR290JVB/C, VGN-SR290JVH/C
