Discover the Sony WH-ULT900N headphones, where innovation meets exceptional sound. Engineered with Dual Noise Sensor Technology and Active Noise Canceling, these headphones are designed to provide an immersive audio experience by filtering out ambient noise, allowing you to focus solely on the music. Bluetooth 5.2 technology ensures seamless wireless connectivity, while the option for wired connection via a 3.5 mm jack or USB-C offers flexibility for all your audio needs.
Comfort is key with the WH-ULT900N. The adjustable headband and foldable design make it easy to find the perfect fit and take your music on the go. Full-size ear cups envelop your ears in sound, not pressure, ensuring comfort during extended listening sessions. With smart features like built-in Alexa and Google Assistant, wear detection, and Dynamic Head Tracking, these headphones are not just about listening; they're about enhancing your audio experience in every aspect. Whether you're at home or on the move, the Sony WH-ULT900N headphones are your gateway to a world of sound quality and convenience.
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
Advanced audio clarity
Experience audio clarity with Sony's Dual Noise Sensor Technology and Active Noise Canceling feature, ensuring an immersive listening experience by effectively minimizing background noise. -
Seamless connectivity
With Bluetooth 5.2 and a variety of connectivity interfaces including a 3.5 mm jack and USB-C, the WH-ULT900N offers versatile wired and wireless connections to suit all your audio needs. -
Comfort and convenience
Designed for long listening sessions, these headphones feature an adjustable headband, foldable design, and full-size ear cups, making them both comfortable and portable. -
Smart technology integration
Equipped with intelligent assistants like Alexa and Google Assistant, and features such as wear detection and Dynamic Head Tracking, the WH-ULT900N headphones are crafted for a smart, intuitive user experience. -
Superior sound quality
Delight in the rich, detailed sound with a wide frequency response of 5 - 20,000 Hz, neodymium magnets, and Sony's DSEE technology, enhancing your audio content to near high-resolution quality.
- Sony WH-ULT900N - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless, wired - 3.5 mm jack
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- Full size binaural
- Foldable
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.2
- Sound Effects
- Digital Sound Enhancement Engine (DSEE), 360 Reality Audio, Ambient Sound Mode, Adaptive Sound Control
- Audio Specifications
- Frequency Response 5 - 20000 Hz - Sensitivity 110 dB/mW
- Impedance
- 32 Ohm
- Active Noise Canceling
- Noise Isolating
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Beamforming, omni-directional
- Microphones Included
- 4
- Intelligent Assistant
- Alexa built-in, Google Assistant
- Product Type
- Series
- Ult Power Sound Series
- 255 g
- Black
- Body Material
- Recyclable plastic
- Recommended Use
- Dynamic Head Tracking, wind noise reduction structure, wear detection, auto power off
- Max Operating Distance
- 10 m
Audio Output
- Headphones Cup Type
- Closed
- Foldable
- Dynamic
- Wireless, wired
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, LDAC
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Serial Copy Management System (SCMS-T), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Headset Profile (HSP)
- Sound Effects
- Noise Isolating
- 5 - 20000 Hz
- Sensitivity
- 110 dB/mW
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
- Adjustable Headband
- Simultaneously Connectable Devices Qty
- 2
- Processor V1, Precise Voice Pickup Technology, MultiPoint Technology, Google Fast Pair, Microsoft Swift Pair
Microphone
- Form Factor
- Built-in
- 4
- Noise Cancelling Technology
- Dual Noise Sensor Technology
Tracking
- Sensors
- Capacitive sensor
- Connector Type
- USB-C (power only) (24 pin USB-C)
Cable
- Detachable Cable
- Cable Length
- 1.2 m
- Plated Connector
- Gold
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- Carrying case, USB charge cable, headphones cable (1.2 m)
- Cable Details
- USB charge cable - detachable , Audio cable - detachable - L shaped / mini-phone stereo 3.5 mm - 1.2 m
- JEITA, Bluetooth Class 1
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 50 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling off): up to 50 hours , Continuous playback (AAC, active noise-cancelling on): up to 30 hours , Continuous talk (active noise-cancelling off): up to 40 hours , Continuous talk (active noise-cancelling on): up to 30 hours
- Recharge Time
- 3.5 hour(s)
- 0 °C
- 40 °C
