Sony ULT WEAR Noise Cancelling Wireless Headphones - Black
Quicklinx: HY0FWS00 Mfr#: WHULT900NB.CE7
Type: Headphones
Connectivity: Bluetooth, Wireless
Colour: Black
Colours:
Hurry, only 3 left in stock!
£98.34 ex VAT
£118.00 inc VAT
Express delivery Order within the next 21 hours for delivery on Monday
Discover the Sony WH-ULT900N headphones, where innovation meets exceptional sound. Engineered with Dual Noise Sensor Technology and Active Noise Canceling, these headphones are designed to provide an immersive audio experience by filtering out ambient noise, allowing you to focus solely on the music. Bluetooth 5.2 technology ensures seamless wireless connectivity, while the option for wired connection via a 3.5 mm jack or USB-C offers flexibility for all your audio needs.
Comfort is key with the WH-ULT900N. The adjustable headband and foldable design make it easy to find the perfect fit and take your music on the go. Full-size ear cups envelop your ears in sound, not pressure, ensuring comfort during extended listening sessions. With smart features like built-in Alexa and Google Assistant, wear detection, and Dynamic Head Tracking, these headphones are not just about listening; they're about enhancing your audio experience in every aspect. Whether you're at home or on the move, the Sony WH-ULT900N headphones are your gateway to a world of sound quality and convenience.
INTRODUCING THE ULT WEAR
With huge, powerful bass, next-level clarity, and seriously impressive noise cancelling, take the ULT POWER SOUND experience, wherever you go.
DESIGNED FOR POWER
Using Sony’s Integrated Processor V1 and high-quality 40mm driver units, ULT WEAR deliver a powerful listening experience, perfect for the bassline obsessives.
HIT THE BUTTON, FEEL THE BASS
Unleash ULT WEAR’s two unique sound modes by pushing the ULT button - Deep Bass adds even more weight to the lower frequencies, while Attack Bass ramps up the energy.
NOISE CANCELLING WITH AMBIENT SOUND
Block out distractions and fully focus on your music with these noise cancelling headphones, or hear your surroundings with Ambient Sound mode.
LISTEN IN COMFORT, AND STYLE
The over ear headphones are designed to be comfortable, even when used for long stretches of time. The compact, durable carry case makes them easy to take anywhere.
CLEAR CALL QUALITY
Featuring Beam Forming Microphones and our Precise Voice Pickup technology, hands-free calls are always easy to understand with ULT WEAR, even when you’re surrounded by noise.
LONG BATTERY LIFE
Enjoy 30-hour battery life when noise cancelling is switched on, or 50 hours when switched off. Quick charging provides 1.5 hours of playback from a 3-minute charge.
EASY CONNECTIVITY
Connect two Bluetooth devices at once with Multipoint Connection. Connecting your wireless headphones to Android/Windows 10 devices is simpler than ever with Fast Pair/Swift Pair.
  • Advanced audio clarity
    Experience audio clarity with Sony's Dual Noise Sensor Technology and Active Noise Canceling feature, ensuring an immersive listening experience by effectively minimizing background noise.
  • Seamless connectivity
    With Bluetooth 5.2 and a variety of connectivity interfaces including a 3.5 mm jack and USB-C, the WH-ULT900N offers versatile wired and wireless connections to suit all your audio needs.
  • Comfort and convenience
    Designed for long listening sessions, these headphones feature an adjustable headband, foldable design, and full-size ear cups, making them both comfortable and portable.
  • Smart technology integration
    Equipped with intelligent assistants like Alexa and Google Assistant, and features such as wear detection and Dynamic Head Tracking, the WH-ULT900N headphones are crafted for a smart, intuitive user experience.
  • Superior sound quality
    Delight in the rich, detailed sound with a wide frequency response of 5 - 20,000 Hz, neodymium magnets, and Sony's DSEE technology, enhancing your audio content to near high-resolution quality.
Sony WH-ULT900N - headphones with mic
Headphones - Bluetooth - wireless, wired - 3.5 mm jack
Recommended Use
Portable electronics
Headphones Form Factor
Full size binaural
Foldable
Wireless, wired
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.2
Sound Effects
Digital Sound Enhancement Engine (DSEE), 360 Reality Audio, Ambient Sound Mode, Adaptive Sound Control
Audio Specifications
Frequency Response 5 - 20000 Hz - Sensitivity 110 dB/mW
Impedance
32 Ohm
Noise Isolating
Microphone Technology
Electret condenser
Microphone Operation Mode
Beamforming, omni-directional
Microphones Included
4
Intelligent Assistant
Alexa built-in, Google Assistant
Series
Ult Power Sound Series
255 g
Body Material
Recyclable plastic
Recommended Use
Dynamic Head Tracking, wind noise reduction structure, wear detection, auto power off
Max Operating Distance
10 m
Audio Output
Full size binaural
Headphones Cup Type
Closed
Foldable
Dynamic
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, LDAC
Bluetooth Version
Bluetooth 5.2
Bluetooth Profiles
Serial Copy Management System (SCMS-T), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Headset Profile (HSP)
Sound Effects
Noise Isolating
Frequency Response
5 - 20000 Hz
Sensitivity
110 dB/mW
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
Adjustable Headband
Simultaneously Connectable Devices Qty
2
Processor V1, Precise Voice Pickup Technology, MultiPoint Technology, Google Fast Pair, Microsoft Swift Pair
Microphone
Built-in
Electret condenser
4
Noise Cancelling Technology
Tracking
Sensors
Capacitive sensor
Connector Type
USB-C (power only) (24 pin USB-C)
Cable
Detachable Cable
Cable Length
1.2 m
Plated Connector
Gold
Internet of Things (IoT)
Carrying case, USB charge cable, headphones cable (1.2 m)
Cable Details
USB charge cable - detachable , Audio cable - detachable - L shaped / mini-phone stereo 3.5 mm - 1.2 m
JEITA, Bluetooth Class 1
Headphone battery rechargeable - Lithium Ion
Run Time (Up To)
50 hour(s)
Run Time Details
Continuous playback (active noise-cancelling off): up to 50 hours , Continuous playback (AAC, active noise-cancelling on): up to 30 hours , Continuous talk (active noise-cancelling off): up to 40 hours , Continuous talk (active noise-cancelling on): up to 30 hours
Recharge Time
3.5 hour(s)
Type: Headphones
Connectivity: Wireless
Colour: Black
Brand: Sony
