Sony SAL1650 16-50mm f/2.8 Zoom Lens A Mount for Alpha
Quicklinx: 9V28WS00 Mfr#: SAL1650.AE
SAL1650 is a high quality standard telephoto lens, ideal for wide range of everyday applications, including portraits, travel, landscapes and general-purpose shooting. Bright F2.8 maximum aperture allows creation of smooth background defocus effects (bokeh). High performance optics achieve versatile zoom range in light, easy-to-carry lens body. Internal SSM (Super Sonic wave Motor) drive achieves exceptionally fast, quiet autofocus - ideal for stills and HD movie shooting. Aspherical lens elements and ED glass elements suppress aspheric and chromatic aberration for superb resolution and contrast. Rugged weather-resistant design with interlocking seals protects against effects of dust and moisture.
  • DT lens design
    A more compact lens is designed specifically for use with APS-C size sensors.
  • Wide f/2.8 aperture
    The SAL1650 features a large f/2.8 aperture for fast response and superb depth-of-field.
  • Aspherical lens elements
    To correct visual aberrations at wide-angle setting, enabling a lightweight lens to capture more visually accurate wide-angle shots.
  • ED (Extra-low Dispersion) glass
    To reduce chromatic aberration at telephoto extension, correcting certain wavelengths of light for sharp, clear images with well defined colors.
  • Circular aperture
    Because aperture blades form a near circle at the wide openings used for low-light shots, spot-light sources have a pleasing circular defocused effect.
Sony SAL1650 - zoom lens - 16 mm - 50 mm
Lens System
Zoom lens
Intended For
Digital SLR
Mounting Type
Sony A-type
Lens Aperture
F/2.8
Focal Length
16 mm - 50 mm
Optical Zoom
3 x
Min Focus Distance
30 cm
Focus Adjustment
Automatic, manual
Lens Construction
13 groups / 16 elements
Special Functions
Zoom
Filter Size
72 mm
Length
8.8 cm
0.58 kg
? SLT-A57, SLT-A57K, SLT-A57M, SLT-A57Y, SLT-A58, SLT-A58K, SLT-A58M, SLT-A58Y, SLT-A65, SLT-A65VK, SLT-A65VL, SLT-A65VM, SLT-A65VY
Length
8.8 cm
Diameter
8.1 cm
0.58 kg
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Digital SLR
Focal Length
16 mm - 50 mm
Lens Aperture
F/2.8
Minimum Aperture
F/22
Focal Length Equivalent to 35mm Camera
24 - 75mm
Optical Zoom
3 x
Magnification
0.2
Min Focus Distance
30 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
83 degree(s)
Min View Angle
32 degree(s)
Lens Construction
Filter Size
72 mm
Diaphragm Blades
7
Mounting Type
Sony A-type
ED glass, aspherical lens, Supersonic-Wave Motor (SSM), dustproof, weatherproof
Lens hood, dust cap, lens cap
Sony a SLT-A57, SLT-A57K, SLT-A57M, SLT-A57Y, SLT-A58, SLT-A58K, SLT-A58M, SLT-A58Y, SLT-A65, SLT-A65VK, SLT-A65VL, SLT-A65VM, SLT-A65VY
