Sony Replacement lamp for VPL-DW120; VPL-DX120; VPL-DX140
Quicklinx: 9RKKWS00 Mfr#: LMP-D213
£541.94 ex VAT
£650.32 inc VAT
  • Enhanced brightness
    The ultra high-pressure mercury lamp with a 210 W capacity ensures your presentations are vivid and bright, even in well-lit rooms. Its high wattage allows for clearer, more impactful visuals, making it an ideal choice for professional settings where clarity is paramount.
  • Seamless compatibility
    Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup. Its compatibility ensures a hassle-free installation process, allowing you to upgrade your projector's performance without the need for complex adjustments or technical support.
Sony LMP-D213 - projector lamp
Projector lamp - ultra high-pressure mercury - 210 Watt
VPL-DW120, DW125, DX120, DX125, DX140, DX145
Projector lamp
Lamp
Ultra high-pressure mercury
210 Watt
Sony VPL-DW120, DW125, DX120, DX125, DX140, DX145
Type: Projector lamp
Brand: Sony
Price Range Ex VAT: £500 - £750
