Enjoy extraordinary lifelike sound at home and on the go with the PULSE Explore™ wireless earbuds.
Discover a new era of gaming audio as studio-inspired planar magnetic drivers reproduce soundscapes with ultra-low distortion to deliver rich details and enable you to hear exactly what the game developers intended.
Feel the action with clear deep bass, and elevate your perception with more precise positioning of audio cues in 3D Audio supported PS5® games.
Never miss a beat as new ultra-low latency and lossless PlayStation Link™ wireless technology delivers sound at lightning-fast speed without losing a single audible detail in the process. Easily connect and switch between PlayStation Link compatible devices, including your PS5 console, PC or Mac® and PlayStation Portal™ remote player.
Connect your earbuds to a mobile device via Bluetooth® while still connected to a PlayStation Link device to take calls and enjoy music as you play uninterrupted. Ensure friends hear your voice loud and clear through two hidden microphones equipped with AI-enhanced noise rejection technology, while easy-access volume controls let you keep your eyes on the game.
Take the PULSE Explore wireless earbuds on your adventures thanks to its light, portable form factor that offers up to 5 hours of play on a single charge. Plus, get back into the action even when you’re away from home with the included charging case that offers up to 10 hours of additional battery life.
Built-in battery and charging case
Stay in play with up to 5 hours of battery life and up to extra 10 hours via the included charging case. -
Integrated microphones
Take calls and chat with teammates through two hidden mics. -
Intuitive controls
Keep your head in the game with easy-access volume buttons. -
Next-generation gaming audio
Enjoy extraordinary lifelike sound in your favorite games. -
PlayStation Link technology
Never miss a beat as ultra-low latency and lossless PlayStation Link wireless technology delivers sound at lightning-fast speed without losing a single audible detail in the process. Easily connect and switch between PlayStation Link compatible devices. -
Be heard loud and clear with microphone noise-rejection technology. Powered by artificial intelligence, this technology has been trained to identify, isolate, and remove unwanted noises when capturing your voice. -
Bluetooth connectivity
Go mobile by directly connecting your earbuds to a mobile phone or tablet device. -
Dual device connectivity
Listen to audio from a PlayStation Link and Bluetooth device simultaneously to stay in play as you answer calls or enjoy music from a mobile device.
- Sony PULSE Explore - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth / PlayStation Link - USB-A via Bluetooth adapter
- Recommended Use
- Game console, phone, computer
- Gaming
- Midnight black
- Headphones Form Factor
- In-ear
- Wireless Technology
- Headphones Technology
- Planar magnetic
- Sound Output Mode
- Stereo
- Microphone Noise Cancelling
- Controls
- Volume, microphone on/mute
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth / PlayStation Link - wireless - USB-A via Bluetooth adapter
- Dimensions & Weight Details
- Earbud: 3.5 cm x 1.9 cm x 2.3 cm / 6.1 g , Charging case: 8.8 cm x 3.8 cm x 4.2 cm / 71 g , USB-A adapter: 4.8 cm x 0.8 cm x 1.6 cm / 4 g
- 3.5 cm
- 1.9 cm
- 2.3 cm
- 6.1 g
- Midnight black
- Recommended Use
- Gaming
- PlayStation Link technology, ClearVoice microphone technology
Audio Output
- In-ear
- Planar magnetic
- Connectivity Technology
- Wireless
- Sound Output Mode
- Stereo
- Simultaneously Connectable Devices Qty
- 2
Microphone
- Form Factor
- Built-in
- Noise Cancelling
- Noise Cancelling Technology
- AI-enhanced noise rejection
Remote Control
- Controls
- Connector Type
- Bluetooth
- Included Accessories
- 3 pairs of ear tips, charging case (780 mAh), USB cable, PlayStation Link USB adapter
- Cable Details
- USB cable
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 105 mAh
- Run Time (Up To)
- 5 hour(s)
- Run Time Details
- Continuous playback (with included charging case): up to 10 hours
- Limited warranty - 1 year
- 5 °C
- 35 °C
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J0X5 051244 Condition: Customer return - item has been used and shows signs of use/ cleaned |
£107.28 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
