Sony PS5 Pulse 3D Wireless Headset White Grade A
Quicklinx: HTWVWS00 Mfr#: 400016904/GRADEA
Enjoy a seamless, wireless experience with a headset fine-tuned for 3D Audio on PS5 consoles. The PULSE 3D wireless headset features a refined design with dual noise-cancelling microphones, USB Type-C charging, and an array of easy-access controls.
  • 12 months warranty
  • Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
  • Re-sealed, original packaging
  • Fine-tuned for 3D audio
    The PULSE 3D wireless headset has been specifically tuned to deliver the 3D audio made possible by the PlayStation 5 console. Powered by Tempest 3D AudioTech, the PS5 console can put you at the center of incredibly immersive soundscapes where it feels as if the sound comes from every direction.
  • Refined design
    Play in style with a sleek headset that perfectly complements the look of the PS5 console and features refined ear pads and headband strap for added comfort.
  • Dual hidden microphones
    Ensure you're heard by your friends online with two built-in microphones, optimally positioned for crystal-clear voice capture and enhanced by noise-cancelling technology.
  • Easy-access controls
    Adjust your set-up as you play with built-in mic mute, master volume and in-game audio to chat mix controls. Easily check how you sound to your teammates too with the dedicated mic monitoring button.
Sony PULSE 3D - headset - 3.5 mm jack
Headset - wireless - 3.5 mm jack
Recommended Use
Game console
Headphones Form Factor
Full size
Wireless
Sound Effects
3D Audio by Tempest 3D AudioTech
Microphone Noise Cancelling
Controls
Microphone on/mute, master volume, chat mix controls, in-game audio
Sony PlayStation 5
21.3 cm
9.1 cm
19 cm
Recommended Use
Game console
Audio Output
Full size
Wireless
Sound Effects
Microphone
Built-in
Noise Cancelling
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm) , USB (power only) (USB Type-C)
Audio cable, wireless adapter, USB-C charging cable
Cable Details
Headphones cable , USB-C charge cable
Headset battery rechargeable
Run Time (Up To)
12 hour(s)
Shipping Width
22.05 cm
Shipping Depth
13.05 cm
Shipping Height
22.45 cm
Sony PlayStation 5
