Enjoy a seamless, wireless experience with a headset fine-tuned for 3D Audio on PS5 consoles. The PULSE 3D wireless headset features a refined design with dual noise-cancelling microphones, USB Type-C charging, and an array of easy-access controls.
- 12 months warranty
- Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
- Re-sealed, original packaging
Fine-tuned for 3D audio
The PULSE 3D wireless headset has been specifically tuned to deliver the 3D audio made possible by the PlayStation 5 console. Powered by Tempest 3D AudioTech, the PS5 console can put you at the center of incredibly immersive soundscapes where it feels as if the sound comes from every direction. -
Refined design
Play in style with a sleek headset that perfectly complements the look of the PS5 console and features refined ear pads and headband strap for added comfort. -
Dual hidden microphones
Ensure you're heard by your friends online with two built-in microphones, optimally positioned for crystal-clear voice capture and enhanced by noise-cancelling technology. -
Easy-access controls
Adjust your set-up as you play with built-in mic mute, master volume and in-game audio to chat mix controls. Easily check how you sound to your teammates too with the dedicated mic monitoring button.
- Sony PULSE 3D - headset - 3.5 mm jack
- Product Type
- Headset - wireless - 3.5 mm jack
- Recommended Use
- Game console
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Sound Effects
- 3D Audio by Tempest 3D AudioTech
- Microphone Noise Cancelling
- Controls
- Microphone on/mute, master volume, chat mix controls, in-game audio
- Designed For
- Sony PlayStation 5
- Product Type
- 21.3 cm
- 9.1 cm
- 19 cm
- Recommended Use
- Game console
Audio Output
- Full size
- Wireless
- Sound Effects
Microphone
- Form Factor
- Built-in
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , USB (power only) (USB Type-C)
- Included Accessories
- Audio cable, wireless adapter, USB-C charging cable
- Cable Details
- Headphones cable , USB-C charge cable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 12 hour(s)
- Shipping Width
- 22.05 cm
- Shipping Depth
- 13.05 cm
- Shipping Height
- 22.45 cm
- Designed For
