Sony PS5 Pulse 3D Wireless Headset White
Quicklinx: HR7RWS00 Mfr#: 400016904
How Games Were Made to Sound™
Enjoy a seamless, wireless experience with a headset fine-tuned for 3D Audio on PS5™ consoles1.
The PULSE 3D™ wireless headset features a refined design with dual noise-cancelling microphones, built-in rechargeable battery, and an array of easy-access controls.
Refined design
Play in style with a sleek headset that perfectly complements the look of the PS5 console and features refined earpads and a headband strap for added comfort.
Designed for gamers
Dual hidden microphones
Ensure you’re heard by your friends online2 with two built-in microphones, optimally positioned for clear voice capture and enhanced by noise-cancelling technology.
Easy access-controls
Adjust your set-up as you play with built-in mic mute, master volume and in-game audio to chat mix controls. Easily check how you sound to your teammates too with the dedicated mic monitoring button.
Take your adventures further
Wireless adaptor
Enjoy up to 12 hours of wireless play thanks to the built-in rechargeable battery. Connect to PS5 and PS4™ consoles as well as compatible Windows and macOS® computers using the included adaptor.
3.5mm jack
Simply plug the headset into PlayStation®VR as well as mobile devices with the included 3.5mm jack audio cable3.
1 Available when feature is supported by game.
2 Internet and account for PlayStation™Network required. Account holders must be 7+, under 18s require parental consent. Full terms apply: playstation.com/PSNTerms.
3 Built-in headset controls not supported on PS VR and mobile devices.
"PlayStation", "PlayStation Family Mark", "PS4", "PS5 logo" and "PS5" are registered trademarks or trademarks of Sony Interactive Entertainment Inc. "SONY" is a registered trademark of Sony Corporation. "How Games Were Made To Sound" is a registered trademark or trademark of Sony Interactive Entertainment LLC. USB Type-C® is a registered trademark of USB Implementers Forum. macOS® is a trademark of Apple, Inc., registered in the U.S. and other countries.
