Enjoy a seamless, wireless experience with a headset fine-tuned for 3D Audio on PS5 consoles. The PULSE 3D wireless headset features a refined design with dual noise-cancelling microphones, USB Type-C charging, and an array of easy-access controls.
Fine-tuned for 3D audio
The PULSE 3D wireless headset has been specifically tuned to deliver the 3D audio made possible by the PlayStation 5 console. Powered by Tempest 3D AudioTech, the PS5 console can put you at the center of incredibly immersive soundscapes where it feels as if the sound comes from every direction. -
Refined design
Play in style with a sleek headset that perfectly complements the look of the PS5 console and features refined ear pads and headband strap for added comfort. -
Dual hidden microphones
Ensure you're heard by your friends online with two built-in microphones, optimally positioned for crystal-clear voice capture and enhanced by noise-cancelling technology. -
Easy-access controls
Adjust your set-up as you play with built-in mic mute, master volume and in-game audio to chat mix controls. Easily check how you sound to your teammates too with the dedicated mic monitoring button.
- Sony PULSE 3D - headset
- Product Type
- Headset - wireless
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Product Type
Audio Output
- Full size
- Wireless
Microphone
- Form Factor
- Built-in
- Battery
- Rechargeable
