Sony PS5 HD Camera
Sony PS5 HD Camera
Quicklinx: G06HWS00 Mfr#: 9321200
Personalize your gameplay sharing
Featuring dual lenses for 1080p capture and a built-in stand, the HD camera works seamlessly with the PS5™ background removal tools to put you in the spotlight. Quickly create a recording or a broadcast of yourself and your gameplay, with your DualSense™ wireless controller’s create button.
Capture unmissable moments
1080p capture
Capture yourself in smooth, sharp full-HD with the camera’s dual wide-angle lenses as you live out your most epic gaming moments. Quickly create a recording or a broadcast of yourself and your gameplay, with your DualSense™ wireless controller’s create button1.
Built-in stand
Get the perfect shot with the HD camera’s built-in adjustable stand.
Its compact design allows it to be securely positioned above or below TVs – where you can fine-tune the angle to suit your set-up.
Background removal tools
Take center stage in your productions using the PlayStation®5 console’s built-in background removal tools. With the HD camera, you can add yourself to your gameplay videos while broadcasting1 in picture-in-picture mode, with the ability to crop the background or lose it completely with a green screen.
1 Internet and account for PlayStation™Network required. Account holders must be 7+, under 18s require parental consent. Full terms apply: www.playstation.com/PSNTerms.
"PlayStation", "PlayStation Family Mark", "PS5 logo", "PS5" and "DualSense" are registered trademarks or trademarks of Sony Interactive Entertainment Inc. "SONY" is a registered trademark of Sony Corporation.
  • 1080p capture
    Capture yourself in smooth, sharp Full HD with the camera's dual wide-angle lenses as you live out your most epic gaming moments. Quickly create a recording or a broadcast of yourself and your gameplay.
  • Built-in stand
    Get the perfect shot with the HD camera's built-in adjustable stand. Its compact design allows it to be securely positioned above or below TVs - where you can fine-tune the angle to suit your set-up.
  • Background removal tools
    With the HD camera, you can add yourself to your gameplay videos while broadcasting in picture-in-picture mode, with the ability to crop the background or lose it completely with a green screen.
Sony HD Camera - webcam
Webcam - fixed
10 cm x 7.5 cm x 4.1 cm
Black, white
Wired
Camera
Max Resolution
1920 x 1080
Video Modes
1080p
Built-in stand, Dynamic Background Removal
Webcam
Wired
10 cm
7.5 cm
4.1 cm
Camera
Colour - fixed
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Digital Video Capture Resolution
1920 x 1080
Black, white
