Built with high performance and personalization in mind, this controller invites you to craft your own unique gaming experience so you can play your way.
Perfect Your Gameplay™
Find your edge with customizable controls and swappable profiles that can help equip you for anything from pro level tournaments to epic single player adventures.
Ultra-customizable controls
Custom settings make your DualSense Edge wireless controller uniquely yours.
Changeable stick caps - Three types of changeable stick caps help you stay comfortable in-game without sacrificing grip or stability.
On-controller user interface - Quickly swap between your pre-set control profiles and adjust game volume and chat balance from the controller’s dedicated function button. (Analogue audio connection to headset required for full compatibility. Audio balance adjustable when in party chat.)
Replaceable stick modules - Play for longer with swappable replacement stick modules available to purchase separately.
Mappable back buttons - Two swappable sets of back buttons, configurable to many other button inputs, put essential controls at your fingertips.
Adjustable trigger lengths - Manually set the travel distance of your left and right triggers for an optimal experience with whatever you’re playing.
USB braided cable with lockable connector housing - Lock the included 9.1ft/2.8m USB cable in place so it's much less likely to slip out at a crucial moment.
DualSense™ wireless controller features built in
Experience all the immersive features of the DualSense wireless controller, including haptic feedback, adaptive triggers, a built-in microphone, motion controls and more in supported titles.
Signature comfort and slip-resistant inner grips
Enjoy the same signature comfort of the original DualSense wireless controller, now enhanced with slip-resistant inner grips. Ideal for long sessions in single player games and staying comfortable during intense competitive play.
Compatible with the DualSense charging station
Keep two controllers fully charged - including your DualSense Edge wireless controller - with the quick and easy click-in design of the DualSense charging station, available to buy now. (Sold separately).
Find your edge with customizable controls and swappable profiles that can help equip you for anything from pro level tournaments to epic single player adventures. -
Custom settings make your DualSense Edge wireless controller uniquely yours. -
Quick access profile settings menu
Simply press the Fn button and Options button while in game to open the customization menu, where you can quickly change your settings. -
Remappable buttons
Customize the control layout of your favorite games so the commands you need are always exactly where you want them to be. Save your button configurations to your player profile and switch between them without leaving your game. -
Adjustable triggers, stick sensitivity and vibration intensity
Configure your stick sensitivity, stick dead zones, and trigger dead zones for finely tuned inputs, and even set your vibration intensity for a completely customized play experience. -
Quick-swap control profiles
Once you've found your ideal control settings, you can save them to unique profiles and swap between them on-the-fly, so your favorite configurations are always ready when you are. -
Enjoy the same signature comfort of the original DualSense wireless controller, enhanced with slip-resistant inner grips. Ideal for long sessions in single player games and staying comfortable during intense competitive play.
- Sony DualSense Edge - gamepad - wireless - Bluetooth
- Product Type
- Gamepad
- Connectivity Technology
- Wireless - Bluetooth
- Controls
- PS button, directional buttons, action buttons, dual point touch pad, Options button, L1 Button, R1 Button, R2 Button, L2 Trigger, Create button, Left stick / L3 Button, Right stick / R3 Button, Touch Pad button, Mute button
- Built-in speaker, headset port, profile switch, vibration, built-in microphone, adjustable vibration, capacitive touch pad, Click Mechanism, SIXAXIS motion technology, Light Bar, three-axis gyroscope, three-axis accelerometer, built-in USB-C charging port, Trigger Effect, adjustable triggers, buttons remap, adjustable stick sensitivity
- 1-year warranty
- Designed For
- Sony PlayStation 5
- Product Type
- Gamepad
- Controls
- Interface
- USB-C
- Battery
- Rechargeable - Lithium Ion
- Included Accessories
- USB cable, carrying case, 2 high dome caps, 2 low dome caps, 2 half dome back buttons, 2 lever back buttons, connector housing
- Limited warranty - 1 year
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H5PZ 048591 Condition: Customer return - item has been opened but is in excellent condition |
£115.61 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
